IFC Export from FreeCAD
Re: IFC Export from FreeCAD
Attached a simple FreeCAD file. The wall will not export to ifc but I don't have any idea why?
- schachimport.fcstd
- (8.55 KiB) Downloaded 131 times
I don't understand why your wall doesn't export, it's very weird. Simply, IfcImport.Entity("IfcWall") doesn't work at some point. Never seen anything quite like that!
Thanks for informations. Mhh, the geometry was originally imported by ifc (but a more complex file withe rebars). If I use the body and create a new Arch wall the export works. Mhh I'm trying to investigage myself too.yorik wrote:... IfcImport.Entity("IfcWall") doesn't work at some point. Never seen anything quite like that!
I look at it since yesterday and cannot find what is wrong... That's crazy!
Ok I finally found the error... For some reason, the string "IfcWall" was sometimes exported as utf8 instead of plain ASCII, which IfcOpenShell didn't like. This is now solved.
Thomas also did some fixes in IfcOpenShell itself, and raised the precision of the float numbers, which seems to solve all problems of non-connecting edges. The testhouse2 now imports much better in my test apps. Revit still doesn't like the ellipse columns, though, and the S wall doesn't work well in all apps yet.
I also added code to separate openings in distinct object, so more and more objects are exported as extrusions instead of brep.
