ifcpipeline a online ifc viewer
This forum section is only for IFC-related issues
thomas-neemann
Re: ifcpipeline a online ifc viewer
Post by thomas-neemann »
ebrahim raeyat wrote: Mon Feb 14, 2022 11:38 am ...
Yes, I also think FreeCAD is Very Slow in large models. ...
there is actually no case where it is necessary to work in an ifc file. if you convert it to a mesh, freecad runs fast and you can e.g. reference everything.
here to see from in 0:21
https://www.youtube.com/watch?v=XSUmlo8vZZk
phpBB [video]
ebrahim raeyat
Post by ebrahim raeyat »
thomas-neemann wrote: Mon Feb 14, 2022 11:47 am
Thanks. I want 2 things:
1- unique name in my etabs and freecad model. I mean each object must be known with same name or label in two model.
2- I want to be able to edit the model (parametric model) and then export the model to ETABS.
thomas-neemann
ebrahim raeyat wrote: Mon Feb 14, 2022 12:42 pm ping
I don't know etabs. i created a test ifc file from create simple copy of a wall. does the name of the wall arrive in etabs?
Wall001001.ifc
(3.08 KiB) Downloaded 67 times
ebrahim raeyat
thomas-neemann wrote: Mon Feb 14, 2022 1:00 pm
Excuse me, maybe I am wrong. I don't want to send Ifc file to etabs, because this way, I have lost many features in my model, like loads and etc. . I want to Import my model from etabs into freecad (with my importer) and then apply some change on it ( in this step freecad is very slow), and then export it to etabs (with my exporter).
thomas-neemann
ebrahim raeyat wrote: Mon Feb 14, 2022 1:31 pm ping
ifc is used for bim processes. only the author of an ifc file changes it (usually). but not by ifc import and export but by e.g. open the fcstd or rvt or dwg file, modify it and export a new ifc file. what you describe is more of a case for step or iges
JellyPalm
Post by JellyPalm »
thomas-neemann wrote: Mon Feb 14, 2022 2:04 pm
Hi Thomas:
You are correct - in practice. But it is like this because of political decision by corporates who are paranoid about people 'stealing', their Intellectual property:
IFC was a very 'slim' version of the model - given (under restrictions) to contractors etc. - with just enough info & refs for them to do their work..
But, there should be no need for us to slim the imported IFC down even further for it to work smoothly in FreeCAD.
That's an OK work-around if FC isn't performing well, but should not be the end goal.
From the point of view of designers and end-users - more, faster, prettier, is generally better.
thomas-neemann
JellyPalm wrote: Thu Feb 17, 2022 4:32 am
I believe a well done ifc file is small and fast
ebrahim raeyat
thomas-neemann wrote: Thu Feb 17, 2022 4:39 am
my model is consist of 120000 area object and frames and My freecad file has about 17 Mb in size. although, it is slow in ETABS software, But in FreeCAD it is very slow that can be work with it
thomas-neemann
ebrahim raeyat wrote: Thu Feb 17, 2022 9:31 am ping
I would do it this way
https://forum.freecadweb.org/viewtopic. ... 10#p571719
