Cannot Export to IFC with 0.19_pre
This forum section is only for IFC-related issues
bernd
Re: Cannot Export to IFC with 0.19_pre
Post by bernd »
l_pereztato wrote: Tue Jan 04, 2022 3:34 pm I have the same problem when importing House.ifc
OS: Ubuntu 20.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.
Branch: unknown
Hash: 472c09cd09a02209e1179d25e0a727db5d374ebb
Python version: 3.8.10
Qt version: 5.12.8
OCC version: 7.5.2
Ar you sure you have the same problem. This topic is old and has been fixed and it is about export of ifc. You having problems with the import. Would you give more information what your problem is and which file you have used.
bernd
l_pereztato
Post by l_pereztato »
Hi Bernd. Thanks for your reply.
Well, probably posting in this topic was not such a good idea. The question is that I've found it when searching information about the "failed to compute placement" error message I'm getting here: https://forum.freecadweb.org/viewtopic. ... 18#p558918 and I've tried to import the same file "House.ifc" trying to get a better understanding of the problem and I get the same error message:
11:33:43 failed to compute placement
11:33:43 Failed to rebuild a valid solid for object Component
11:33:43 Failed to rebuild a valid solid for object Component001
11:33:43 Finished importing 0.0 MB in 0 seconds, or 20 s/MB
I'll update the issue I've opened and stop posting in this topic.
