Can't Open ParaView 5.11.0 With FreeCad 0.20.1
Moderator: oliveroxtoby
EveningSkyPerson
Post by EveningSkyPerson »
Hello -- Thank You for any help in advance. Using CAELinux, In FreeCAD 0.20.1 I am trying to open ParaView 5.11.0. In FreeCAD under Edit/Preferences/cfdOF/ParaView executable path, (using the little box on the right) I put '/home/mike/Applications/ParaView-5.11.0-RC1-osmesa-MPI-Linux-Python3.9-x86_64/bin/mpiexec'. In the status box of the CFD tab it says 'Paraview started'. But it never opens. Please Help!
OS: CAElinux2020 (XFCE/xubuntu)
Version: 0.20.1.29410 (Git) AppImage
Branch: (HEAD detached at 0.20.1)
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Installed mods:
  * CfdOF 1.19.1
  * Plot 2022.4.17
Re: Can't Open ParaView 5.11.0 With FreeCad 0.20.1
Moved from Help forum.
oliveroxtoby
Post by oliveroxtoby »
EveningSkyPerson wrote: Thu Oct 20, 2022 11:36 pm Hello -- Thank You for any help in advance. Using CAELinux, In FreeCAD 0.20.1 I am trying to open ParaView 5.11.0. In FreeCAD under Edit/Preferences/cfdOF/ParaView executable path, (using the little box on the right) I put '/home/mike/Applications/ParaView-5.11.0-RC1-osmesa-MPI-Linux-Python3.9-x86_64/bin/mpiexec'. In the status box of the CFD tab it says 'Paraview started'. But it never opens. Please Help!
You should select 'paraview' rather than 'mpiexec' as the executable.
EveningSkyPerson
Hello -- Thank You so much that some one of your horsepower would reply with an answer to my question. I tried using 'paraview' at the end off the paraview executable path instead of 'mpiexec', but got the same result -- in the status box of the CFD mesh tab it says 'Paraview started' , but it never opens. I am following 'Run a CFD analysis in CAELinux' video by Joko Engineering, but he is using ParaView 5.9.1 -- I was not able to find that to download it if that makes a difference. Thank You so much for your time.
Michael Farneti
