Boundary type not appropriate to determine initial pressure
Moderator: oliveroxtoby
poulmack
Post by poulmack »
Hi all,
I am running a simple simulation with an inlet of 0.1 kg/s and an outlet as open boundary (attached file). The mesh runs ok with cfMesh, but when trying to write the case, the following errors appear
0.0: Error writing case:
0.0: RuntimeError: Boundary type not appropriate to determine initial pressure.
0.0: Write case setup file failed
OpenFOAM v2206
cfMesh for V2206
Any help will be really appreciated.
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * CfdOF 1.17.2
  * Help 1.0.3
  * ProDarkThemePreferencePack 1.0.0
Regards,
Paul
Room split.FCStd
(35.76 KiB) Downloaded 35 times
Budahn
Re: Boundary type not appropriate to determine initial pressure
Post by Budahn »
Go to initialize fields and put the pressure with specify value and it should work
poulmack
Post by poulmack »
Thanks for your answer @Budahn ,
I did that and there is another error.
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux              : 1e-300
Specified mass inflow   : 0.083333333
Specified mass outflow  : 0
Adjustable mass outflow : 0
I understand that potential flow helps to converge easily, so that shouldn't be a problem/solution
Room split.FCStd
(35.78 KiB) Downloaded 35 times
oliveroxtoby
Post by oliveroxtoby »
poulmack wrote: Sun Jul 17, 2022 8:23 pm Hi all,
The problem is you have selected 'inlet' as the boundary to copy pressure from (in InitialiseFields). Since pressure isn't specified in that boundary type, it can't be used. Choose your 'open' bounary instead.
oliveroxtoby
poulmack wrote: Mon Jul 18, 2022 2:57 am Thanks for your answer @Budahn ,
Total flux              : 1e-300
The 'open' boundary isn't being picked up since that face doesn't exist on the object you are meshing. Changing the Part property of your mesh object from 'Body' to the 'BooleanFragments' object sorts it out. It should have given you a warning that the boundary is not matched though - I'll look into that.
