Hi, i cant start the simulation, when i try the message "OpenFOAM fatal error: --> FOAM FATAL ERROR: OpenFOAM fatal error: --> FOAM FATAL ERROR: OpenFOAM fatal error: --> FOAM FATAL ERROR: OpenFOAM fatal error: (openfoam- " appears and i dont know why. Also theres one value in the turbulence specification that show a forbidden symbol, i tried deleting the ")" and when i do it te ok symbol shows but at the moment i press enter in order to close the task it appears again.
OS: Windows 10 Version 1903
Version: 0.19.24267 +148 (Git)
Branch: Branch_0.19.4
Hash: 476ecf091941bead59b14e44afa6064d5a66afa3
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Locale: Spanish/Argentina (es_AR)
Problem starting a Turbulent simulation with LES
Moderator: oliveroxtoby
- Sin título.png (20.14 KiB) Viewed 880 times
Re: Problem starting a Turbulent simulation with LES
Please at least give more info about your goal and best is to share the model.
- oliveroxtoby
I remember this bug from some earlier FreeCAD versions. It should be fixed if you update to the latest release.
Please provide all the information requested in this post before reporting problems with CfdOF.
