Error reported: failed to launch 'renumberMesh
Moderator: oliveroxtoby
poulmack
Post by poulmack »
I am trying to run a simple case and installed OpenFOAM-v2112 with Microsoft MPI in the attached file. I understand the later tool is necessary for decomposition.
The mesher runs all ok and can visualize in Paraview, but when I try to run the solver, I get the following error
10:58:25 ERROR: Error reported: failed to launch 'renumberMesh -parallel -overwrite' on DESKTOP-PAUL
Error (2) The system cannot find the file specified.
10:58:25
Is it necessary to edit decomposeParDict in Windows Explorer or CfdOF can do this automatically? What's the best way to solve this error?
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * CfdOF 1.17.0
  * Help 1.0.3
Regards,
Paul
Room split.FCStd
(38.56 KiB) Downloaded 32 times
ondrejch
Re: Error reported: failed to launch 'renumberMesh
Post by ondrejch »
OS: Ubuntu 22.04 LTS (MATE/mate)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
  * ProDarkThemePreferencePack 1.0.0
  * A2plus 0.4.56a
  * CfdOF 1.17.0
It ran on my system, with the following error:
07:36:19  Part::FeaturePython: Link(s) to object(s) 'Sketch002 Pad001' go out of the allowed scope 'BooleanFragments'.
Instead, the linked object(s) reside within 'Body Body Body'.
07:36:19  Part_BooleanFragments: only one solid in the result, generating trivial compsolid.Part::FeaturePython: Link(s) to object(s) 'Sketch002 Pad001' go out of the allowed scope 'BooleanFragments'.
07:36:19  Part_BooleanFragments: only one solid in the result, generating trivial compsolid.188.471
<App> Document.cpp(3546): Room_split#BooleanFragments still touched after recompute
poulmack
Post by poulmack »
Hi @ondrejch ,
Were you able to get the results in Paraview?
Regards,
Paul
oliveroxtoby
Post by oliveroxtoby »
poulmack wrote: Sun Jun 26, 2022 5:07 pm The mesher runs all ok and can visualize in Paraview, but when I try to run the solver, I get the following error
10:58:25
No, it's not necessary. The error should now be fixed if you update your workbench.
