[solved] CAARC building, cfmesh error
Moderator: oliveroxtoby
thschrader
Post by thschrader »
can someone have a look at this file:
CAARC.FCStd
(43.14 KiB) Downloaded 61 times
I want to run this example:
https://www.dlubal.com/en-US/support-an ... ase/001624
I tried to reconstruct the mesh (3 volume refinement stages, one surface refinement, no boundary layer elements)
When using snappyhexmesh, meshing and sim works, but cfmesh gives back an error, see below.
cfdof-wb is "fresh", what am I doing wrong?
Thanks
cfmesh message:
10:24:41  Generating stack trace...
10:24:41
Backtrace:
	ZN10StackTraceC1Ev [0x626c1855+0x25]
		 module: C:\PROGRA~1\BLUECF~2\ThirdParty-8\platforms\mingw_w64GccDPInt32\lib\libstack_trace.dll
	ZN4Foam5error10printStackERNS_7OstreamE [0x6c30ae5a+0x23a]
		 module: C:\PROGRA~1\BLUECF~2\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\lib\libOpenFOAM.dll
	ZN4Foam6sigFpe13sigFpeHandlerEi [0x6c30b693+0x33]
	(No symbol) [0x401fe2]
		 module: C:\PROGRA~1\BLUECF~2\ofuser-of8\platforms\mingw_w64GccDPInt32Opt\bin\cartesianMesh.exe
	_C_specific_handler [0x7ff93f547ff8+0x98]
		 module: C:\WINDOWS\System32\msvcrt.dll
	0_chkstk [0x7ff9410120cf+0x11f]
		 module: C:\WINDOWS\SYSTEM32\ntdll.dll
	RtlRaiseException [0x7ff940fc1454+0x434]
	KiUserExceptionDispatcher [0x7ff941010bfe+0x2e]
	ZN4Foam13edgeExtractorD1Ev [0x61f4a5df+0x112f]
		 module: C:\PROGRA~1\BLUECF~2\ofuser-of8\platforms\mingw_w64GccDPInt32Opt\lib\libmeshLibrary.dll
	GOMP_parallel [0x63606dc9+0x49]
		 module: C:\PROGRA~1\BLUECF~2\ofuser-of8\platforms\mingw_w64GccDPInt32Opt\bin\libgomp-1.dll
	ZN4Foam13edgeExtractor38distributeBoundaryFacesNormalAlignmentEv [0x61f4d9fd+0x17d]
	ZN4Foam13edgeExtractor12extractEdgesEv [0x61f4f1be+0x1e]
	ZN4Foam22cartesianMeshGenerator14extractPatchesEv [0x6201e205+0x55]
	ZN4Foam22cartesianMeshGenerator12generateMeshEv [0x6201edf0+0x330]
	ZN4Foam22cartesianMeshGeneratorC2ERKNS_4TimeE [0x6201f317+0x4b7]
	(No symbol) [0x402f14]
	(No symbol) [0x4013c1]
	(No symbol) [0x4014f6]
	BaseThreadInitThunk [0x7ff93fe57034+0x14]
		 module: C:\WINDOWS\System32\KERNEL32.DLL
	RtlUserThreadStart [0x7ff940fc2651+0x21]
10:24:41
OS: Windows 10 Version 2009
Version: 0.20.27428 (Git)
Hash: 27460358508a2057e0ec57a418641435f12628dd
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
trijonb
Re: CAARC building, help needed
Post by trijonb »
I gave this a try, and didn't seem to have an issue (meshing or solving) - although the meshing (with cfMesh) did take quite a long time, and was quite memory intensive. Unless its something to do with v0.20, did you perhaps run out of memory?
Version: 0.19.24267 +99 (Git)
Branch: Branch_0.19.3
Hash: 6530e364184ce05ccff39501e175cf2237e6ee4b
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Locale: English/New Zealand (en_NZ)
thschrader
trijonb wrote: Thu Apr 21, 2022 10:06 am I gave this a try, and didn't seem to have an issue (meshing or solving)
Thanks for testing.
Which cfmesh-version do you use?
My:
trijonb
Post by trijonb »
"cfMesh-CfdOF (cfMesh 1.1.2) 1.12"
I'm using ESI's cross compilation version though
thschrader
Did some testing:
-reinstalled cfmesh
-using FC0.19 ==> cfmesh crashes
-using FC0.20 Conda built instead of LP ==> cfmesh crashes
When running some older files with a more complicated design and refinement zones,
there is no problem. There must be a modelling error in the CAARC-model, which I have overlooked.
Easy looking things can be hard...
oliveroxtoby
Post by oliveroxtoby »
thschrader wrote: Fri Apr 22, 2022 2:24 pm Did some testing:
-reinstalled cfmesh
It runs fine for me, including on blueCFD 2020. As a further check, could you zip up and share the 'meshCase' folder after clicking 'Write mesh case' so that we can eliminate any problem on the FreeCAD/CfdOF side?
thschrader
CAARC-model and meshcase:
CAARC.FCStd
(42.94 KiB) Downloaded 58 times
meshCase_CAARC.zip
(6.55 KiB) Downloaded 52 times
And a working model:
buildings.FCStd
(153.35 KiB) Downloaded 65 times
Case writing needs 3 min, be patient. Written stl has 207 MB...
done with bluecfd2020 and
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
oliveroxtoby
thschrader wrote: Sat Apr 23, 2022 7:10 am meshCase_CAARC.zip
Thanks - I was able to reproduce the error with the mesh case. Should be fixed now if you update cfMesh.
thschrader
oliveroxtoby wrote: Tue Apr 26, 2022 7:42 pm Thanks - I was able to reproduce the error with the mesh case. Should be fixed now if you update cfMesh.
Done. Works.
Thanks a lot.
oliveroxtoby
thschrader wrote: Sat Apr 23, 2022 7:10 am Case writing needs 3 min, be patient. Written stl has 207 MB...
That issue should be resolved now...
