Hello everyone!
Is there any way to use external meshers for CFD OF workbench?
Let me explain. I’m just a beginner in FreeCAD and CFD OF. For educational purposes I created a simple air bearing model to simulate air flow in the 0.1 gap between shaft and bush. My problem is: none of built-in meshers can create a proper mesh. Either it creates a broken mesh (in case when cell size is big), or it runs into infinite loop – 2.5 hours – no result (when cell size is 0.05 mm).
I installed standalone mesher – Netgen 6.2, which is perfect for my purposes. Fully automatically it rapidly creates optimized refined mesh. Here starts the trouble – I’m not able to use this perfect mesh. I tried simply replacing the broken mesh in the mesh case with the proper one (remember, I’m just a beginner and not able to use “raw” OpenFoam without GUI). And FreeCAD even was able to load the proper mesh in the view. But the solver can’t use it and stops.
I’m attaching my FreeCAD container. The Forum engine doesn't allow me to attach the mesh, generated with Netgen, as it's too big. Here's the link to the cloud: https://drive.google.com/file/d/14wac-q ... sp=sharing
External meshers using
Moderator: oliveroxtoby
- Air bearing design.FCStd
- (160.19 KiB) Downloaded 18 times
- oliveroxtoby
Re: External meshers using
Unfortunately this isn't possible at the moment (unless you start using OpenFOAM utilities directly on the case). Adding an interface to Netgen may be a good idea but isn't a trivial job.
As far as I can tell, there isn't an up-to-date "NetgenToFoam" function, but there are ones for Fluent/.msh, STAR-CD/Prostar, GAMBIT/.neu, IDEAS/.ans, and CFX/.geo. How hard do you think it would be to incorporate the existing OpenFOAM mesh conversion functions? It seems to me like I could just add a Qt panel somewhere and have some form of "Convert mesh" button hooked up to a line of bash–is there something about the way CfdOF works that would make that trickier than it seems?oliveroxtoby wrote: ↑Sun Mar 20, 2022 7:40 pm unless you start using OpenFOAM utilities directly on the case
- oliveroxtoby
It would be great to have that as an option. The only complication I can think of would be defining the boundary conditions on the imported mesh. I think this could be achieved by outputting the surface .stl files as is currenty done when meshing with cfMesh or snappyHexMesh, and then running the surfaceToPatch utility to redefine the boundary patches of the imported mesh.KAKM wrote: ↑Tue Mar 22, 2022 6:14 am How hard do you think it would be to incorporate the existing OpenFOAM mesh conversion functions? It seems to me like I could just add a Qt panel somewhere and have some form of "Convert mesh" button hooked up to a line of bash–is there something about the way CfdOF works that would make that trickier than it seems?
On the subject, it would also be nice to be able to import meshes from the FEM workbench. If I recall correctly, Qingfeng's original CFD workbench actually used (uses?) FEM functions for its meshing, outputting to .unv files which were then converted using unvToFoam. So a similar approach to the above could be followed. In case you have the energy!
- oliveroxtoby
I was talking nonsense here - of course, for an imported mesh you probably don't have the geometry already; the mesh should define the geometry. One would want to be able to link up the boundary conditions to the pre-existing patches on the mesh, so we would need to add this as an option to the boundary conditions. i.e., for an imported mesh, you should be able to choose patch names in the BCs rather than them being matched to shapes.oliveroxtoby wrote: ↑Tue Mar 22, 2022 7:50 pmIt would be great to have that as an option. The only complication I can think of would be defining the boundary conditions on the imported mesh. I think this could be achieved by outputting the surface .stl files as is currenty done when meshing with cfMesh or snappyHexMesh, and then running the surfaceToPatch utility to redefine the boundary patches of the imported mesh.KAKM wrote: ↑Tue Mar 22, 2022 6:14 am How hard do you think it would be to incorporate the existing OpenFOAM mesh conversion functions? It seems to me like I could just add a Qt panel somewhere and have some form of "Convert mesh" button hooked up to a line of bash–is there something about the way CfdOF works that would make that trickier than it seems?
