Techdraw - Dimensioning at contour curves with asymmetric radii
Hi all,
when drawing asymmetrical contour radii I encountered the following problem, for the dimensioning of the radius sections usually tangents are needed. I could not find an automatic function for this in FC. Unfortunately, I could only help myself by drawing them in a separate sketch "underneath".
My question is now:
Could an automatic function be programmed for this, which can be switched on and off?
My question is now:
Re: Techdraw - Dimensioning at contour curves with asymmetric radii
Please elaborate. I don't understand what you mean by "asymmetric radii" nor do I see a TechDraw page in your file, which could have helped to better understand.
I added the TD page in my file.
What I mean is e.g. :
You have a symmetric contour radius:
R20 = x20 y20
An unsymmetric contour radius:
R20 = x17, y23
For dimensioning the unsymmetric radii, TD cannot supply any intersection points.
They can only be very elaborately inserted by cosmetic vertex (points) and are usually inaccurate.
R20 = x20 y20
R20 = x17, y23
- Shalmeneser
Do you know Sketcher_ConstrainTangent ?
I don't understand unsymmetric contour radius.
A fillet has ONE radius.
For TWO radius, you need TWO arcs :
- Capture d’écran 2023-01-15 160518.jpg (17.07 KiB) Viewed 1361 times
I'm talking about ONE radius!
- Shalmeneser
what is the meaning of : R20 = x17, y23 ?
The dimensioning of the radius in x- respectively y-direction.
See:
Just said, that have nothing to do with symmetry. The term you search is intersecting points.
Depends, i know many controls of CNC, they need only the intersection points and fillet radius. Besides that the intersecting points can be need for any other things in drawings and documentations.
Greetings
user1234
- Shalmeneser
You need to use an ellipse's arc.
- EllipticalFillet_SHALM.FCStd
- (8.45 KiB) Downloaded 31 times
- Capture d’écran 2023-01-15 204200.jpg (14.81 KiB) Viewed 1245 times
