[solved] Weekly 021-31527 TechDraw dimensions cause crashes
FBXL5
Post by FBXL5 »
Hello community!
TechDraw in the new weekly build 0.21-31527 gives me headaches: Dimensions let FreeCAD crash!
The menu of the dimension tools is reordered; this can be observed as long no dimension has been involved so far.
I still can open files with active TechDraw pages without dimensions.
Then I cannot
- use any dimensioning tool, FC crashes at the moment a tool is selected
- read a file containing at least one dimension; it opens and starts to display some views (if 2D is active), but when it comes to show dimensions FC crashes. :(
Can someone confirm this behaviour?
OS: macOS 10.16
Version: 0.21.0.31527 (Git)
Hash: 664b2560adcd9c9ab012e4f8c0fb92143c202fe9
Python 3.10.8, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: C/Default (C)
Installed mods:
  * freecad.gears 1.0.0
  * fcgear 1.0.0
  * Render 2022.4.0
  * Curves.backup1662374221.0929039
  * fasteners 0.4.52
  * sheetmetal 0.2.60
  * Curves 0.6.5
  * Assembly3 0.11.4
wandererfan
Re: Weekly 021-31527 TechDraw dimensions cause crashes
Post by wandererfan »
FBXL5 wrote: Mon Jan 09, 2023 3:36 pm Can someone confirm this behaviour?
New and old dimensions work with this
OS: Linux Mint 20.3 (X-Cinnamon/cinnamon)
Version: 0.21.0.31529 +1 (Git)
Build type: debug
Branch: removeLogMessages
Hash: bf35fbeebd4a904f1d575fca626a03b5b2f7fcc9
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk , OCC 7.6.3
Installed mods:
  * sheetmetal 0.2.59
  * FreeCAD_Electric
  * Assembly4 0.12.4
  * A2plus 0.4.56a
user1234
Post by user1234 »
No, opened 0.20 and 0.21.master files with dimensions, created dimensions. Created a complete new file and made dimensions, works all.
OS: Debian GNU/Linux 11 (bullseye) (X-Cinnamon/lightdm-xsession)
Version: 0.21.0.31544 (Git)
Hash: 297389acae715dedd59465afc9e0f90db1e53aa7
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 9.0.1, OCC 7.6.3
Installed mods:
  * QuickMeasure 2022.10.28
  * CurvedShapes 1.0.4
  * Curves 0.6.5
Greetings
user1234
FBXL5
Post by FBXL5 »
wandererfan wrote: Mon Jan 09, 2023 5:14 pm New and old dimensions work with this
(0.21.0.31529 +1)
user1234 wrote: Mon Jan 09, 2023 6:12 pm No, opened 0.20 and 0.21.master files with dimensions, created dimensions. Created a complete new file and made dimensions, works all.
(0.21.0.31544)
Linux seems to be safe.
It looks like I have to wait for next build to get rid of a crashing TechDraw. (At least all versions up to 0.21.0.31513 still work fine)
In the meantime my other computer can open files containing TechDraw dimensions, but it is impossible to add new dimensions, instead FC crashes. :(
OS: macOS 10.15
Installed mods:
  * Reinforcement
  * fcgear 1.0.0
  * Render 2022.4.0
  * fcgear.backup1662890180.767765
  * fasteners 0.4.52
  * sheetmetal 0.2.60
  * Help 1.0.3
  * Curves 0.6.5
  * Assembly3 0.11.4
At least I can have a look at the new Repair dimension references dialog to create sensible translations in Crowdin.
wandererfan
FBXL5 wrote: Mon Jan 09, 2023 6:46 pm
I'll try with a test file that crashes if you have one to share.
FBXL5
Post by FBXL5 »
wandererfan wrote: Mon Jan 09, 2023 11:55 pm I'll try with a test file that crashes if you have one to share.
Thanks. This file (without any magic features) was made with 0.21.0.31340 and can be opened with 0.21.0.31527 so far:
Snip macro screenshot-0db0e2.png (13.93 KiB) Viewed 1505 times
TechDrawCrash.FCStd
(19.2 KiB) Downloaded 36 times
I can select a line, but the moment I click any of the dimensioning tools (except extend dimensions) FC disappears completely.
wandererfan
FBXL5 wrote: Tue Jan 10, 2023 7:49 am
Same revision, but different OS, Python, Qt, Vtk and add-ons, so I'm not sure this tells us much. Do we have a mac developer? I can't think of one off hand.
Build type: Unknown
Branch: test527
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.3
Installed mods:
  * sheetmetal 0.2.59
  * FreeCAD_Electric
  * Assembly4 0.12.4
  * A2plus 0.4.56a
FBXL5
Post by FBXL5 »
wandererfan wrote: Tue Jan 10, 2023 7:18 pm
My hope is that the problem disappears with the next weekly build.
@chrisb, does your Mac crash, too if you try to set dimensions in TechDraw with version 0.21.0.31527 as described above?
domad
Post by domad »
FBXL5 wrote: Tue Jan 10, 2023 7:49 am ....
Hello FBXL5, greetings to the Community!
@wandererfan I confirm no problem here:
Version: 0.21.0.31527 (Git) AppImage
Locale: Local
with the file "TechDrawCrash.FCStd"
I attach the file with an excess of 3D dimensioning.
TechDraw_no_Crash.FCStd
(33.67 KiB) Downloaded 30 times
domad
Post by domad »
domad wrote: Wed Jan 11, 2023 11:06 am ....
@wandererfan
....however if I open the file "SSDlx_3D_domad-2" (built with version "FreeCAD_weekly-builds-31513-2023-01-08-conda-Windows-x86_64-py310" with Windows10) FreeCad loads it correctly, reporting however errors in the report, after a few seconds to complete the loading it crashes closing immediately, event that doesn't happen with FC-0.21-31513 windows, however TechDraw becomes exaggeratedly slow.
I attach the file divided into two parts, due to "weight" (over one Mb).
SSDlx_3D_domad-002.7z
(511.19 KiB) Downloaded 32 times
SSDlx_3D_domad-001.7z
(512.21 KiB) Downloaded 29 times
