[Solved] "Pan" function limited in movement
domad
Re: "Pan" function limited in movement
Post by domad »
wandererfan wrote: Thu Jan 12, 2023 3:23 pm ....
Hello wandererfan, greetings to the Community!
Finally I found something that affects the malfunction.
If from the TechDraw preferences I set A4 as the default page/format, and then set/change the Template parameter from the properties to a format greater than A3, then the problem arises.
If from TechDraw preferences I set A0 as the default page/format, and then set the Template parameter on smaller formats from the properties, the problem seems to disappear, and everything works perfectly, even if I create a new page with an A0 Template, the malfunction does not occur.
wandererfan
Post by wandererfan »
domad wrote: Thu Jan 12, 2023 5:54 pm
Ah-hah! The scrollable area was not being reset on a change of template. The fix is in the queue.
Excellent detective work!
domad
Post by domad »
wandererfan wrote: Fri Jan 13, 2023 2:55 pm ... he fix is in the queue.
Greetings to the Community!
@wandererfan , Okay! Very well, thank you!
wandererfan
domad wrote: Fri Jan 13, 2023 4:26 pm
Should be fixed by git commit e1dc7bd94b
domad
Post by domad »
wandererfan wrote: Sat Jan 14, 2023 12:12 am ...
Un saluto alla Comunità!
@wandererfan 👍
domad
Re: [Solved] "Pan" function limited in movement
Post by domad »
Problem well solved with the FC 0.21-31641 version, but perhaps it was already solved also in the previous one (I haven't tried it) :D
