rich61 wrote: ↑Thu Dec 29, 2022 11:15 am
Problem are not here to defend or deny a post, as probably @domad answer is what trigger your answers (please link the message you are replying so it is more easy to spot the matter and the meaning of an answer)
As from other forum, I think that domad is not denying the importance of such things, but he consider the "process" of integrating changes in FreeCAD or in TechDraw in this case.
Probably the point is that if a similar discussion have already been done, and some "good reasons" to not proceed with modifications have been raised from developers, is better to see "what is the problems" and "where are the difficult steps", and what developers have answered, before to make further considerations.
EDIT:
I've read other topics, and probably wanderefan has already answered that the modification is not a simple thing:
https://forum.freecadweb.org/viewtopic. ... 45#p650045
https://forum.freecad.org/viewtopic.php ... d7#p649879
And IMHO they are not a deny of the problem it is simply that "now" is not the "best time" to do this sort of things, as there is already many things to be done by developers.
Sadly this could not be the answer you expect, but if you have some time and skills to submit code you could even try to "help development"
END EDIT.
Following part is about my personal opinion about "TNP mitigation".
FreeCAD sources "now" are in the process of integrating a "TNP mitigation" solution, and this involve modifying lot of code and testing many things.
So probably trying to make "too much things" and coding maybe some difficult to obtain things when there is an underlying "big code modification" will not be a "clever use of coding time".
FreeCAD development is not "stopped" or "slowed down", or even "stalled" as some critics seems to suggest, from time to time, but is simply "done behind the scenes", and probably is very active, as this "big change" is not so easy as some people seems to think. It is true that there is RealThunder LS3 version that has it integrated from some time now, but it true also that RT version is not "in sync" with actual FreeCAD sources, (even RT admit that he sync source from time to time as it is difficult to maintain in sync two "diverging" code base).
A little thing that seems to be not guessed by some critics is that RT is "one man" and not a "team of developers" so we all have to thank RT for having not simply "made his own version" and developing "his version" only, but instead working hard to integrate some of "his solutions" in the FreeCAD codebase, this thing is not too common even in OpenSource ecosystem, as usually the "forks" tend to diverge and not to "converge", and this lead not unusually to "different type of software".
Kind Regards
Carlo D.
