Design Idea: Sketcher 'Point' and TechDraw
If a 'Point' object is created in Sketcher, it does not appear in TechDraw.
Points are stored and retrieved in sketch, but I don't see the point illustrated in the 3D model image. In another thread I illustrated how I was able to use the SplitEdge function to create a point that show up in TechDraw without changing the shape of the part.
Of course SplitEdge creates a 'Point' or vertex object and connects the resulting two lines, which to stay intact need to also have a colinear (tangent) constraint applied. A 'Point' would be much better.
Is it possible to make the Point show up in TechDraw ? Is it easy ? Is this a worthwhile idea to others ?
A point constrained to a 'point of interest' in the Sketch, could serve as a good way to dimension a property in Techdraw.
- adrianinsaval
Re: Design Idea: Sketcher 'Point' and TechDraw
sketcher points are created as construction geometry (and are therefore not shown in 3D) you can turn them into normal geometry with the toggle construction command and they will show up in 3d.
Thanks, it worked, that shows my sketch point on the surface of my model. But it isn't available in TechDraw as far as I can see.
When in non-construction mode, if I make a circle it is red, and a real feature. When I place a point is automatically a construction feature?
If I make a line in non-construction mode, it is red. If I change that line to construction type, it is blue. Initially when placed, a point is red indicating it is a real object. When I toggle to construction mode, it is white, not blue, but then it appears in the model. Interesting behavior.
I was hoping that it would show up in TechDraw, but seems like it does not.
I wonder why it is not visible to TechDraw ?
How could I find it in the code base ? I should start learning how things are implemented. Maybe I could make an experimental change.
You misunderstand. With the default colors, when the color of a point (Sketcher_CreatePoint) is red in the 3D view, it is construction geometry. So you are not toggling 'to' but 'from' construction mode.rich61 wrote: ↑Wed Dec 28, 2022 12:35 pm If I make a line in non-construction mode, it is red. If I change that line to construction type, it is blue. Initially when placed, a point is red indicating it is a real object. When I toggle to construction mode, it is white, not blue, but then it appears in the model. Interesting behavior.
- adrianinsaval
Probably techdraw only imports edges, the code is likely somewhere in here: https://github.com/FreeCAD/FreeCAD/tree ... chDraw/App
They show up in 3D view but not in TechDraw. This was discussed before and I'm pretty sure that there exists a feature request.
I thank you Adrian and Roy and Chrisb.
There is no feature request yet; see https://forum.freecadweb.org/viewtopic. ... 35&t=65910 .
Thanks for that link, Chrisb. I think I understand that first sentence. There are 3rd party softwares that can not be touched, so some limitations. Does the second sentence refer to some FreeCAD mechanism, "send through the detour" ?
Then I wonder, if a similar workaround could be implemented deeper in the system, so that a circle, splitline, arc, might work since they are DocumentObjects, but because of a specific diameter or threshold dimension could be interpreted as a point. Its probably too messy and has some negative consequences I'm not thinking of.
My application/user level workaround is to use a tiny circle if within the part boundaries. However if you need a point on an edge, you can make a circle then trim it to a tiny arc so that I can use the center point in techdraw, splitedge and collinear constraint is another way. If the diameter/radius is small enough, it looks OK as drawing document.Points don't make it through the projection process. There is a detour for Part and Draft points, but it won't pick up a Sketcher point because it isn't a DocumentObject.
Will have to parse the sketch's Geometry property for points and send them through the detour.
Moved to TechDraw forum. Perhaps has @wandererfan some new ideas.
