[Techdraw] Two issues with Chain Dimensions [1 of 2 fixed]
domad
Re: [Techdraw] Issues with Chain Dimensions
Post by domad »
Greetings to the Community!
I confirm that the different behavior of the alignment function of the dimensions in series, horizontal and vertical, is highlighted in the presence of the comma, it does not happen with the point as a decimal separator, to reproduce the two cases enter the same dimension value by activating the arbitrariness and replacing the comma with the period.
I also point out that the value of the horizontal series dimensions is correctly centered with respect to the dimension line, while it does not happen in case of alignment of vertical series dimensions.
balrobs
Post by balrobs »
balrobs wrote: Wed Aug 10, 2022 7:10 pm I will test the changes and let you know.
Now moved dimensions stay in the right place :D
Thanks to all involved in solving the issue
