missing file on Tolerancing wiki page
david69
Post by david69 »
on Tolerancing, we read:
  • ISO 1101 / ASME Y14.5 Stating and interpreting Geometric Dimensions and Tolerances (Definitions and symbols) 1
  • ISO 16792 / ASME Y14.41 Model-based definitions (CAD data) 3D model presentation and geometric dimensioning and tolerancing 2
at the very end of each line, we are supposed to find files.
the first address is http://www.sharifcadcam.ir/uploaded/2e2 ... 686c4f.pdf, but error 404.
the second one is refered to a file without extension.
can we have the right ones or simply we remove these links.
Roy_043
Re: missing file on Tolerancing wiki page
Post by Roy_043 »
We should definitely remove the 2nd link: It is a licensed PDF file.
Roy_043
Post by Roy_043 »
BTW it seems we are at cross purposes here. I have deliberately removed this page from translation, it is a roadmap after all, not intended for the average user. And I now see that you have reintroduced translation tags.
david69
Post by david69 »
if I put it for translation, it's because there is a reference at the bottom of this table https://wiki.freecadweb.org/Workarounds ... orkarounds, line 16 with GD&T.
I didn't know you put it back for non translation (well I never checked that up to now). I've found that page with the translation of the above page.
I would not called it roadmap, IMO there are information.
TechDraw_Geometric_dimensioning_and_tolerancing talks about Tolerancing, may be the two can be merged.
Roy_043
Post by Roy_043 »
david69 wrote: Wed Aug 03, 2022 8:15 pm may be the two can be merged
They are about two different concepts.
david69
Post by david69 »
all right. we remove the two links?
I see that you have modified the reference link in https://wiki.freecadweb.org/Workarounds ... orkarounds
Roy_043
Post by Roy_043 »
These two links (and the translation tags) have been removed.
