There is lots of stuff going on in the background - Qt event loop stuff mostly, but also garbage collection and dependency propagation. If that core stays busy, then we have to look into this.user1234 wrote: ↑Mon Jul 25, 2022 9:39 am One major issue i found. After recalculating a view (does not matter how), one CPU/thread is still always full loaded, even there is nothing to do. FreeCAD uses permanent >6% CPU load (this is 100% from 16 cores (the CPU have 8 64bit cores, but can split it to 16 virtual cores). When i close the file (not close FreeCAD), it load is normal.
TechDraw Multithread Testing
- wandererfan
Re: Multithread Testing
I have forgot to mention how long i waited. The load (1 CPU for FreeCAD 100%) goes really permanent, the current test is now 25min (edit: now >1h:05min), when i correct remember, the test before was >1/2h. I still can do something in FreeCAD, but noticed at the beginning of handling anything lag.wandererfan wrote: ↑Mon Jul 25, 2022 2:30 pm There is lots of stuff going on in the background - Qt event loop stuff mostly, but also garbage collection and dependency propagation. If that core stays busy, then we have to look into this.
No, git itself (per terminal input). This occur since the first time i used git with qt creator (and i do not use it anymore), since that i have the behavior.
Not yet, but what makes me wonder is, that i can not pull a branch, even i did not change anything. That works before flawless (and still all repositories cloned before i used qt creator the first time). This git is sometimes weird.wandererfan wrote: ↑Mon Jul 25, 2022 2:07 pm Did you do "git config [--global] user.name" and git config [--global] user.email"? If not, that might be why it is asking who you are.
Greetings
user1234
edit: blue
- wandererfan
A quick progress report...
- found a (the?) memory leak
- investigating the high idle speed (high cpu with no activity). The QGraphicsView is repainting even when there is no activity. Could be a bad boundingRect according to google.
Thanks for the update!
Greetings
user1234
- wandererfan
I've just pushed a new version with the memory leak and the high cpu at idle fixed. Same branch.
Still digging into updating dimensions on TechDraw_RedrawPage.
I can't duplicate reliably the issue with getting only 7 of 8 sections painted when loading test46_multithreading_section.FCStd. Seems to work most of the time.
Still to look into is the File functions not working while restoring.
Many thanks!wandererfan wrote: ↑Tue Jul 26, 2022 7:55 pm I've just pushed a new version with the memory leak and the high cpu at idle fixed. Same branch.
I can confirm, that
- high cpu at idle
- the blocking of dialogs like the filedialog
are fixed. With the test, i saw that the memory still increses every loop, but estimated lesser as before (5 loops: 461.7MByte vs. 387.8MByte, when you ignore the normal RAM of FreeCAD, the increase is around 11.9MByte now vs. 25.4MByte before per loop).
wandererfan wrote: ↑Tue Jul 26, 2022 7:55 pm I can't duplicate reliably the issue with getting only 7 of 8 sections painted when loading test46_multithreading_section.FCStd. Seems to work most of the time.
From 10 times i recalculated the views/sections (behavior was on both), i got one view/section, which did not work. On the actual tests, i never had the issue again. So when the CPU/thread was in an infinite loop, maybe this was the issue. I would not investigate it further, till the behavior will occur again, if it ever occur again.
See above, you already fixed it.wandererfan wrote: ↑Tue Jul 26, 2022 7:55 pm Still to look into is the File functions not working while restoring.
The only issue compared to the master is, the missing dimensions whenKeepUpdated is false (geometries like lines works).
Man thanks on working on this, this is indeed a lifetime saver! Even when you only generate new views, it now works really fluent.
Greetings
user1234
I found a small issue. The recalculating of an section detail fails the first time, when you open a file. When you recalculate it per hand (Redraw Page), then it works. When the detail is in a normal view, it works flawless.
Zip file, because it is a linked part.
Greetings
user1234
Greetings
user1234
- wandererfan
New version available that fixes this. Other changes: fix dimensions on redraw when keepUpdated = false, preference on Advanced tab for progress reporting.
Thanks, will test it!wandererfan wrote: ↑Fri Jul 29, 2022 6:31 pm New version available that fixes this. Other changes: fix dimensions on redraw when keepUpdated = false, preference on Advanced tab for progress reporting.
Greetings
user1234
- wandererfan
instructions on how to use the snap of the multithread branch (thanks to @ppd)
# brand new snap install
$ sudo snap install --channel=edge/pr-44 freecad
# If you already have the freecad snap installed
$ sudo snap refresh --channel=edge/pr-44 freecad
# Experimental: Parallel install (see https://snapcraft.io/docs/parallel-installs)
$ sudo snap set system experimental.parallel-instances=true
$ sudo snap install --channel=edge/pr-44 freecad_pr44
$ freecad_pr44 # Run it
