TechDraw PDF export, exports Template text not as text
tobiasfalk
Post by tobiasfalk »
After exporting the drawing the text of the Template is not mark able (not a text)n so at least in Okular, LibreOffice Draw or Adobe Acrobat Reader. The behave in exporting DXF and SVG is completely different. With SVG's there is no real problemn the text is redable and markable(it is "real" text) but with DXF's the template is not exported. I have a PDF and a DXF file attached.
FreeCAD version:
OS: openSUSE Leap 15.3 (KDE//usr/share/xsessions/plasma5)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
FoldLinePen-1-2022-06-23.dxf
(21.09 KiB) Downloaded 33 times
FoldLinePen-1-2022-06-23.pdf
(334.62 KiB) Downloaded 40 times
wandererfan
Re: TechDraw PDF export, exports Template text not as text
Post by wandererfan »
tobiasfalk wrote: Sun Jun 26, 2022 11:35 am After exporting the drawing the text of the Template is not mark able (not a text)n so at least in Okular, LibreOffice Draw or Adobe Acrobat Reader. The behave in exporting DXF and SVG is completely different. With SVG's there is no real problemn the text is redable and markable(it is "real" text) but with DXF's the template is not exported. I have a PDF and a DXF file attached.
Not sure this can be fixed as we use a Qt function to output our PDF files. I found posts on StackOverflow from other people with this issue, but none of the posts had real solutions.
As mentioned in the Limitations section of TechDraw_ExportPageDXF, the template is not included in exported DXF. This would require converting the SVG template into FC geometry and then to DXF.
tobiasfalk
Ok, thx.
Dos that mean that when the Template is FC geometry that it would be exported? If yes is it possible to to create a template as FC geometry? By doing that there would not be a need to convert the SVG to FC geometry.
bensay
Post by bensay »
@wandererfan @tobiasfalk
So apparently, there is a workaround made for SVG: https://github.com/FreeCAD/FreeCAD/blob ... #L731-L733.
A workaround for you then is to export as SVG and then convert the SVG to PDF
