Page 1 of 3
Annotating lines at Dxf
Posted: Fri Jun 24, 2022 10:13 pm
by manos
Does anybody know if it is possible to have annotating lines from TechDraw page to the Dxf ?
Bless you.
Re: Annotating lines at Dxf
Posted: Fri Jun 24, 2022 10:36 pm
by chrisb
Moved to TechDraw forum.
Posted: Fri Jun 24, 2022 11:19 pm
by manos
chrisb wrote: ↑Fri Jun 24, 2022 10:36 pm
OK thanks Crisb sorry for the inconvenience.
Posted: Fri Jun 24, 2022 11:43 pm
by chrisb
manos wrote: ↑Fri Jun 24, 2022 11:19 pm
OK thanks Crisb
You're welcome. It may get here the attention of the right experts. It may be helpful if you upload a file containing such lines which are not exported to dxf. Augment it with detailed steps what to do to reproduce the issue.
Even if such a model is very simple, it takes some time to build it, and every single helper would have to invest that time.
Posted: Sat Jun 25, 2022 7:47 am
by manos
chrisb wrote: ↑Fri Jun 24, 2022 11:43 pm
.. It may be helpful if you upload a file containing such lines which are not exported to dxf.
I used right click and the export command to export to Dxf . I have spent two days of my humble life to make export Dxf with dimensions or leaderlines work, but nothing achieved yet.
Do you really believe that Dxf export works ?
OS: Ubuntu 18.04.5 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.29177 (Git) AppImage
Branch: (HEAD detached at 0.20)
Hash: 68e337670e227889217652ddac593c93b5e8dc94
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
* Help 1.0.3
Posted: Sat Jun 25, 2022 9:01 am
by chrisb
manos wrote: ↑Sat Jun 25, 2022 7:47 am
Partially: yes; completely: no.
Posted: Sat Jun 25, 2022 10:37 am
by manos
chrisb wrote: ↑Sat Jun 25, 2022 9:01 am
So now let's see how we can survive with that partiality.
Posted: Sat Jun 25, 2022 12:46 pm
by ragohix769
manos wrote: ↑Sat Jun 25, 2022 10:37 am
IMHO, just for now, it's not working 100%. You can, as a partial workaround, export in SVG, there it's working percfectly. DXF it's not a really good interchange format, as I understand.
It's not possible to use DXF as an interchange format for annotations, only for 2D Geometry reference, I failed everytime I tried to do that. This a good question in general to undestand how to send our works rich annotated to other people that do not use our beloved FCAD. In the real world, that's a pity, every professional it's using DWG for everything, so we have propietary standard everywere, that's a huge problem and the real obstacle to the FOSS efforts.
Posted: Sat Jun 25, 2022 3:38 pm
by wandererfan
manos wrote: ↑Fri Jun 24, 2022 10:13 pm
The export page command in TechDraw only supports DrawViewPart and DrawViewDimension. The exporter in the Import module can handle text - this is used for the dimension text.
We've never had a request for text before this.
There seems to be a move afoot to replace our 2 dxf handlers -
https://www.forum.freecadweb.org/viewto ... 10&t=69491.
Posted: Sat Jun 25, 2022 3:42 pm
by wandererfan
You may want to look at the Limitations section of
TechDraw_ExportPageDXF.
