0.20 Centerlines don't appear on circular pockets.
techGuy
Post by techGuy »
OS: Ubuntu Core 20 (KDE/plasmax11)
Version: 0.20.29177 (Git) Snap 66
Branch: tag: 0.20
Python 3.8.10, Qt 5.15.3, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.2
Create a body.
Create a sketch for some holes. Draw circle. Pocket the sketch, creating a hole in the body.
Create a Techdraw page.
Select the body. Create a view for it.
Select a hole on a face. Select Add Circle Centerlines. The hole will get deselected and nothing will happen.
NewJoker
Re: 0.20 Centerlines don't appear on circular pockets.
Post by NewJoker »
Can't confirm this:
OS: Windows 10 Version 2009
Branch: releases/FreeCAD-0-20
Locale: Polish/Poland (pl_PL)
openBrain
Post by openBrain »
Can't reproduce with
OS: Ubuntu 21.04 (KDE/plasma)
Build type: Debug
Branch: (HEAD detached at 68e337670e)
Python 3.9.5, Qt 5.15.2, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.2
Locale: English/United States (en_US) [ OS: French/France (fr_FR) ]
Syres
Post by Syres »
Surely this is related to already existing Graphics Issues in Some Linux Configurations https://github.com/FreeCAD/FreeCAD/issues/6698 ??
wandererfan
Post by wandererfan »
techGuy wrote: Wed Jun 22, 2022 4:47 am Select a hole on a face. Select Add Circle Centerlines. The hole will get deselected and nothing will happen.
Need an example file to diagnose. If the file is proprietary, you can attach it to a PM. Best guess is that the hole is not actually a circle, but Add Circle Centerlines should detect this (as Diameter/Radius dimensions do).
user1234
Post by user1234 »
Also could be, that the view in 3D was while making the view in TechDraw, a little bit rotated. Then this the circle is also not a circle and this function does not work. Just look in the properties, if all is straight. If not, you can easily correct that per hand.
Greetings
user1234
techGuy
Post by techGuy »
Syres wrote: Wed Jun 22, 2022 8:41 am Surely this is related to already existing Graphics Issues in Some Linux Configurations https://github.com/FreeCAD/FreeCAD/issues/6698 ??
I was running Qt 5.15.3. That version of Qt appears to fix the issue.
techGuy
Post by techGuy »
wandererfan wrote: Wed Jun 22, 2022 1:23 pm
Sorry, I can't share it.
The hole is a circle in Sketch. I then pocket it. In the reverse direction, if that makes any difference.
techGuy
Post by techGuy »
user1234 wrote: Wed Jun 22, 2022 3:35 pm Also could be, that the view in 3D was while making the view in TechDraw, a little bit rotated.
Nope, it is a 2D view, normal to the plane that it was drawn in.
user1234
Post by user1234 »
Have you checked, if
- the circle is in 3D really a circle? (in the curves wb in the addonmanager, there is a tool for that)
- in the values are a "-" before the "0". Fore example "-0.000", which can mean, that the view value is actual very very small, but not zero.
Or maybe Syres is correct and the graphic issue.
Greetings
user1234
