The TechDraw implementation (at least FreeCAD version 0.19 and newer) inserts a view with current projection. This leads to the following issue: when you make something constructed from different parts and want to make individual drawings for all these parts some of them may requires custom rotation to make main axis vertical or horizontal on drawing. For example, object created here: https://github.com/looooo/freecad.frame ... gate.FCStd. The diagonal supports will be inserted with main axis in diagonal direction on page.
Is it possible to make easy view rotation have main axis of part, for example, horizontal on drawing? The current way is not efficient:
1. Measure angle between main axis and horizontal of page.
2. Update View properties.
When overall design changed these to steps needs to be performed again which is not very convenient. Or I miss something from UI?
Issue #7061 - TechDraw: View orientation
Reason: Added GH ticket number to thread title
- wandererfan
Re: View orientation
How is the program to determine the main axis? I don't see anything in the properties of Main Diagonal (for example) that could tell me directly what rotation should be applied.
Maybe one day we will have grab handles to make rotating easier, but even then, rotating exactly 34.4180* would take a bit of skill with the mouse.
The use can select any edge which he/she wants to make horizontal or vertical. The step could look like:wandererfan wrote: ↑Mon Jun 20, 2022 2:19 pmHow is the program to determine the main axis? I don't see anything in the properties of Main Diagonal (for example) that could tell me directly what rotation should be applied.
1. Select edge.
2. Select command "make vertical" or "make horizontal". The FreeCAD calculates angle and rotates view.
I think such high skill of mouse to get 34.4180* angle is not for me.wandererfan wrote: ↑Mon Jun 20, 2022 2:19 pm Maybe one day we will have grab handles to make rotating easier, but even then, rotating exactly 34.4180* would take a bit of skill with the mouse.
- wandererfan
Yes, with user intervention, this could be done, and no special skill or magic would be required.
issue #7061
