[SOLVED] Dimensioning and rescaling a design
kaktus
Post by kaktus »
Hi.
:mrgreen:
Once again, I found a minor (or not) anomaly. :roll:
I prepared a page with a view of the projections and applied some dimensions.
Then I found that I can change the scale of the object because there is still room on the page.
After changing the scale I was surprised with the result.
The problem occurs in different drawings and is repeatable.
The anomaly concerns "Insert Projection Group" for "View" I was not able to duplicate it.
The version of FreeCAD I am using is:
OS: Debian GNU/Linux bookworm/sid (KDE/plasma)
Version: 0.20.29085 (Git) AppImage
Branch: (HEAD detached at 1e96bbd)
Hash: 1e96bbd2815683d6afa0afe8f985cdd04ef839fe
Python 3.10.4, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: Polish/Poland (pl_PL)
kaktus
Re: Dimensioning and rescaling a design
Post by kaktus »
After restarting FreeCAD, the dimensions are in the correct location. 8-)
:idea:
Previously, the Refresh button was not active.
wandererfan
Post by wandererfan »
kaktus wrote: Thu Jun 16, 2022 8:26 am After changing the scale I was surprised with the result.
Hard to be sure without the file, but it looks like you have a pending recompute. Closing and reopening would have recomputed everything.
If you can share the file, I can try to find out why the recompute doesn't happen automatically.
kaktus
Post by kaktus »
No problem. I added my project to the message.
However, note that I wrote - this happens for every project file. And that the Refresch button is grayed out. :idea:
parasol_ogrodowy_zerdka_detale.FCStd
(45.43 KiB) Downloaded 19 times
wandererfan
kaktus wrote: Fri Jun 17, 2022 4:17 am No problem. I added my project to the message.
Thanks for the file. The dimensions are not being recomputed on change of scale in the parent view.
TechDraw_RedrawPage seems to fix it, but this should happen automatically.
kaktus
Post by kaktus »
Image Yeah this tool does a good job. :mrgreen:
Is it possible to not have to click on this icon and refresh the view automatically :?: The view tool has no such side effects ...
Clicking on TechDraw RedrawPage is a workaround.
wandererfan
kaktus wrote: Fri Jun 17, 2022 2:46 pm Is it possible to not have to click on this icon and refresh the view automatically
Should be fixed by git commit 4b47d38eb6
kaktus
Post by kaktus »
Woow
I'm delighted. :mrgreen:
Yruon
Post by Yruon »
Hello there, :)
I'm sorry if this topics is already open but i can't find it.
I'm actually making a TechDraw of a part. But when i want to rescale it, i just can't. The problem is that the value is in grey, can't use my keyboard, can't use the arrows on the right, can't even use the functional tool.
I tried to check and uncheck the "ReadOnly" tool after right clicking on it, then i can change de the value as i want, but there is no changement between a scal of 1.00 and a one of 0.30 ... :?:
I also got this error message :
Somehting to notice : The part was designed on FreeCAD0.19, and i update to 0.20 to make the TechDraw.
I also tried to install and uninstall the soft, remake the part from 0 on the 0.20 FreeCAD Version. Nothing change.
wandererfan
Yruon wrote: Tue Jun 21, 2022 1:02 pm I'm sorry if this topics is already open but i can't find it.
You have ScaleType set to Page which means the view should use the Scale value from the Page. You can either change the Page's Scale property or set ScaleType to Custom, then set the View's Scale as you wish.
