[Solved] How to get scale higher than 99:1 in TechDraw
Hi everybody, I am working on some miniature parts, where I measure things in microns. Sometimes it would be really handy to share a technical drawing. Unfortunately the highest scale I was able to set is 99:1, and I can't enlarge the Projections any more. Is there any settings, or trick, which could break this barrier, and allow scales higher than 100?
Re: How to get scale higher than 99:1 in TechDraw
No problems to set the scale to 10000 both for the whole page and for a single view. I use 0.20.
OS: macOS 10.16
Version: 0.20.28774 (Git)
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Locale: C/Default (C)
Installed mods:
* FC_SU
* DynamicData 2.46.0
* FeedsAndSpeeds 0.4.0
* fcgear
* Manipulator 1.4.3
* fasteners
* sheetmetal
* ExplodedAssembly
* Curves 0.3.0
* Assembly4 0.11.12
I made some further tests: In the ProjectionGroup dialog the limit is indeed 99, but you can increase it in the properties tab.
Many thanks, Chris! That's right! Though some times ago I had trouble setting it to 100 in the Properties (99 was OK then), but in the current version 28929(Git), it works!
