TD: Pos Vert Chain Dim vs. Position Vertical Chain Dimensions
In CommandExtensionDims.cpp there are some commands whose text is marked for translation like "Pos Vert Chain Dim" and "TechDraw PosVertChainDimension". Later in the same file we have "Position Vertical Chain Dimensions". I think there are a few examples like this. Translators don't really know what to do with the first two, with abbreviated words. Should those actually remain untranslated? Should translators be directed to come up with abbreviations in their languages? Some guidance would be appreciated.
- wandererfan
Re: TD: Pos Vert Chain Dim vs. Position Vertical Chain Dimensions
The "Pos Vert Chain Dim" literal is a transaction identifier and as far as I know this identifier is only visible in the "Undo/Redo dialog" as a reminder of recent steps. So the actual wording here is not critical - something short like "Create Pad" is typical. I might go with "Vertical Chain" in this case.
"TechDraw PosVertChainDimension" appears to be an alternative to the command name "CmdTechDrawExtensionPosVertChainDimension" which is itself troublesome.
I would say the right thing to do would be to rename all these commands to something along the lines of "CmdTechDrawPositionVerticalChain" and adjust the literals accordingly. I think this impacts the wiki/help files and the icons should probably be renamed to match.
Doing the whole job looks like a significant piece of work.
@edi - any comments?
Thanks -- it is used in at least one GUI element, as the title of an error window, on line 615 of CommandExtensionDims.cpp (also a related one on line 557, and as you suggest probably many others...)
If I may make a suggestion: There are three very similar commands now that could be combined into one I think. The first selected dimension would then be used as a filter and determine the action: Horizontal, Vertical or Oblique.
Some other extension commands can perhaps also be combined.
Just something I noticed while looking at the file:
Does this work?:
https://github.com/FreeCAD/FreeCAD/blob ... .cpp#L2250
Does this work?:
QObject::tr(message.c_str())
That call to tr() will only work if the contents of message have previously been added to the translation database by a call to one of the NOOP translation functions.
From what I understand that is not the case. So that would require further attention.
- wandererfan
Yes, you are right.Roy_043 wrote: ↑Fri Jun 03, 2022 9:48 am If I may make a suggestion: There are three very similar commands now that could be combined into one I think. The first selected dimension would then be used as a filter and determine the action: Horizontal, Vertical or Oblique.
In TechDraw (and Sketcher) there are three types of linear dimensions: horizontal, vertical and oblique. In the extension tools this system is continued.
In general it would be more comfortable to have only one linear dimension tool, using the following workflow:
- Select a line or two points
- Click once to define the type of the dimension:
If clicked:
- north or south ... horizontal
- west or east ... vertical
- near the line center or between the points ... oblique
Very comfortable would be (I am dreaming) if the dimension under progress would be shown as "rubber band" hangig at the curser during definition of the type.
This interface is used by other CAD-Systems.
It would be good to collectively come up with new names for the occurrences of which strings should be modified.
