Thanks for reporting. The fix is on the way.
LeaderLine and RichTextAnno Alpha Release
- wandererfan
- wandererfan
Re: LeaderLine and RichTextAnno Alpha Release
Points edit should be fixed by git commit ab986d9a00.
Thanks. I found another problem. The rich text annotation show the same font size.
Version: 0.19.16687 (Git)
Hash: ff1fb11af15a7c5f7f0ba3ef79588e128f397c2c
Python version: 3.6.6
Qt version: 5.6.2
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
- wandererfan
Just to confirm I understand the problem:
* make an RTA with text at non-default size
* reopen RTA editor at a later time.
* RTA sets text at cursor back to default size
Sound right?
That's right. Sorry for my bad description.wandererfan wrote: ↑Fri May 17, 2019 12:54 pmJust to confirm I understand the problem:
Sound right?
::bitacovir::
- wandererfan
Should be better after git commit 15f440525e.
Thanks for these reports. The editor is borrowed code, so it needs a good work out.
I'm really struggling with the DrawLeaderLine using the GUI in both Windows and using the latest Linux AppImage. I can create a LeaderLine fine using Python and it displays correctly but using the GUI, the tree updates, Visible is set to True but I don't see it in the View. I've attached an example file and by all means let me know what I've incorrectly set.
OS: Linux Mint 19.1 (X-Cinnamon/cinnamon)
Version: 0.19.16790 (Git) AppImage
Hash: 15f440525e59c3caf89f847a490981abf5a45f8f
Python version: 3.7.1
Qt version: 5.6.2
OS: Windows 7 SP 1 (6.1)
Version: 0.19.16784 (Git)
Hash: ec5720d51c54e6c433cacf207e773aad09dbb25c
Python version: 3.6.8
Qt version: 5.12.1
Qt version: 5.6.2
Qt version: 5.12.1
- SolidworksExamPiece.FCStd
- (55.79 KiB) Downloaded 34 times
- wandererfan
Thanks for the report.Syres wrote: ↑Sun May 19, 2019 9:00 am I'm really struggling with the DrawLeaderLine using the GUI in both Windows and using the latest Linux AppImage. I can create a LeaderLine fine using Python and it displays correctly but using the GUI, the tree updates, Visible is set to True but I don't see it in the View.
We've had a regression in the positioning code, apparently.
Your leader is still there, just in the wrong place. To fix it for now, set LockPosition to false, then drag the leader to the correct position, then set LockPosition to true to keep it here.
Thanks for the pointer.
- wandererfan
Regression in positioning code should be fixed by git commit 8ef3f13fbb
