LeaderLine and RichTextAnno Alpha Release
wandererfan
Postby wandererfan » Mon May 06, 2019 12:26 pm
Preliminary(alpha) versions of TechDraw_LeaderLine and TechDraw_RichTextBlock are available in master branch.
There is a lot of new code and changed code involved with these 2 tools, so testing is required and bug reports are welcome.
Known issues:
- "not a mouseGrabber" message
--- safe to ignore
- Leader does not always appear after document load
--- recompute or touch leader in tree
- no add/delete node function when editing line
- RT editor needs better integration
---- font, fontSize, maxWidth, etc from ViewProvider
- parent child relationship in tree are not perfect
- assigning RTA to Leader after creation
--- connection not created without save/restore
- cannot trigger editors by double click in graphics area
Thanks for the Rich Text editor go to:
** Copyright (C) 2013 Jiří Procházka (Hobrasoft)
** Contact: http://www.hobrasoft.cz/
** Copyright (C) 2013 Digia Plc and/or its subsidiary(-ies).
** Contact: http://www.qt-project.org/legal
wf
fjullien
Re: LeaderLine and RichTextAnno Alpha Release
Postby fjullien » Mon May 06, 2019 12:38 pm
I did test your work. It looks good.
I don't know if it is what you said here:
but I find something. At some point I ended edition by double clicking. Then, I couldn't move the view anymore:
Plus in RT dialog box, I couldn't find "Save" and "Close":
Franck.
wandererfan
Postby wandererfan » Mon May 06, 2019 5:21 pm
I suspect the bounding rect for the leader is covering the view completely. I confess I tested mostly with more traditional looking leaders. Will have to change the leader bRect calculation to follow the line like we do for Edges.
2 Top left buttons. They are blank in your screen capture. Are the really blank?
What platform are you on?
wandererfan
Postby wandererfan » Mon May 06, 2019 5:29 pm
Save and Exit (document-save and window-close) are supposed to be theme icons.
Can you see the icons for text foreground color and text background color? They are regular icons in Gui/Resources/icons.
bitacovir
Postby bitacovir » Mon May 06, 2019 6:50 pm
Sorry. Where I can download this version?
::bitacovir::
My personal web site
My GitHub repository
My old Blog
Mini Airflow Tunnel Project
fjullien
Postby fjullien » Mon May 06, 2019 7:16 pm
In Gui/Resources/icons/MRTE, I only have icons for text foreground color and text background color. I couldn't find others anywhere.
fjullien
Postby fjullien » Mon May 06, 2019 7:17 pm
I think your only option is to compile it from sources. It is present in upstream master.
wandererfan
Postby wandererfan » Tue May 07, 2019 12:05 am
A little more investigation reveals that the "from theme" option in QtDesigner only works under certain conditions. So I'll have to find real icons for the word processing functions and put them in the resource file.
wandererfan
Postby wandererfan » Wed May 08, 2019 2:22 am
Icons sorted and merged. Thanks to @fjullien for testing.
wf
bitacovir
Postby bitacovir » Wed May 15, 2019 3:56 am
Hi. Thanks for these new features. But in windows, the "Edit points" of DrawLeaderLine does not work.
Version: 0.19.16687 (Git)
Hash: ff1fb11af15a7c5f7f0ba3ef79588e128f397c2c
Python version: 3.6.6
Qt version: 5.6.2
::bitacovir::
My old Blog
