View Positioning is Broken in CoarseView
wandererfan
Postby wandererfan » Tue Jan 23, 2018 11:20 pm
The AutoDistribute option in ProjectionGroup is broken. You'll have to position the various Views manually until it is fixed. :oops:
Edit: changed title to reflect further investigation.
wandererfan
Re: ProjectionGroup AutoDistribute is broken
Postby wandererfan » Thu Jan 25, 2018 2:59 am
AutoDistribute is fine. There seems to be a problem with all View positioning when using CoarseView. Still looking.
wandererfan
Re: View Positioning is Broken in CoarseView
Postby wandererfan » Fri Jan 26, 2018 12:30 am
Documenting the problem in case it takes a while to get around to fixing it.
The attachment RegularAlgoOrtho.png is no longer available
HLRBRep_Algo, ortho projection
wandererfan
Postby wandererfan » Fri Jan 26, 2018 12:37 am
HLRBRep_PolyAlgo, ortho projection
wandererfan
Postby wandererfan » Fri Jan 26, 2018 12:38 am
HLRBRep_PolyAlgo, perspective projection
wandererfan
Postby wandererfan » Sat Jan 27, 2018 7:30 pm
