Hmmm so strange. Thanks for checking.
Interesting to note, that means there is still some unaccounted stuffs going on between file transfers from blender to freecad.
DraftView + DWire and DraftView + Polygon seem fine here. Maybe I'm not understanding? Maybe Draft.getSVG does something odd with DWires?
if the Dwire polygone is drawin on verticaly, i.e on the X,Z or Y,Z planes, it's DraftView will not work, It seems DraftView can only acquire Dwires sketches that are on the same plane as the top view mode for 2D drawing.wandererfan wrote: ↑Wed Jan 10, 2018 12:45 am DraftView + DWire and DraftView + Polygon seem fine here. Maybe I'm not understanding?
Polygon001 is drawn on "Front" working plane in Draft and give DraftView002. Did you change the ProjectionDirection of the DraftView to match the 3D orientation? I don't know why the triangle is rotated by 90* in DraftView002. The creation of the DraftView drawing geometry happens in Draft.getSVG, maybe @Yorik has an idea?
I think you need to set the DraftView / Projection Direction?regis wrote: ↑Wed Jan 10, 2018 3:16 amif the Dwire polygone is drawin on verticaly, i.e on the X,Z or Y,Z planes, it's DraftView will not work, It seems DraftView can only acquire Dwires sketches that are on the same plane as the top view mode for 2D drawing.wandererfan wrote: ↑Wed Jan 10, 2018 12:45 am DraftView + DWire and DraftView + Polygon seem fine here. Maybe I'm not understanding?
Example on DraftView 001 on Face 001 paullee experiement, and the Draft view sketch on my picture, the Dwire flat face of the human next to the extruded human are both perpendicular to the Top view. So when you insert the Draft View of the perpedicular flat face, it provides you with a line, as it it is reading the flat face from the Top automatically.
Yes I also notices some incosistencies along these lines.wandererfan wrote: ↑Wed Jan 10, 2018 4:06 pm I don't know why the triangle is rotated by 90* in DraftView002. The creation of the DraftView drawing geometry happens in Draft.getSVG, maybe @Yorik has an idea?
@yorik care to weigh in?yorik wrote:ping
