Still a geometry change, but in the 2D geometry. The link between 2DEdge[1] and 3DEdge[1] can get messed up if either one of them changes index.ulrich1a wrote:It works in principle also in an isometric view, but only if you are lucky.
Changing the view-direction of the isometric view, let the dimensions flip to wrong edges.
Which was reported before, but at change of geometry.
The Big TechDraw Comments Thread
- wandererfan
Re: The Big TechDraw Comments Thread
- wandererfan
I can't make this happen. Could you post the file, please?NormandC wrote:I figured out why. The dimension I created on the iso view was a vertical distance dimension, because the selected edge is vertical. Linking this dimension to the corresponding edge on the 3D model produces a value of zero.
Can't think of anything but 3D view. I have no idea why I associated "3D view" with "iso view".wandererfan wrote: What is the proper term for the main 3D panel?
Here it is.wandererfan wrote:I can't make this happen. Could you post the file, please?
BTW have a look at the top view, specifically how the round cutout is traced over the chamfered section. It looks like a straight line instead of an arc segment. Sorry, that's a different bug.
- FC017_TechDraw_bug_normandc1.fcstd
- (37.61 KiB) Downloaded 48 times
Cool, thanks. I wasn't aware you had added TechDraw to the wiki.wandererfan wrote: I've updated the wiki page a bit: TechDraw_Dimension_Link
Unable to create total length or width as shown attachment.
- sample 3.fcstd
- (32.63 KiB) Downloaded 47 times
- freecad01.png (15.12 KiB) Viewed 3890 times
It works for me. What version you have. With the newest one you can choose edges and then dimension in older only vertexes.jaisejames wrote:Unable to create total length or width as shown attachment.
BTW nice progres in TechDraw module - wandererfan we are waiting for moreefyx wrote:It works for me. What version you have. With the newest one you can choose edges and then dimension in older only vertexes.jaisejames wrote:Unable to create total length or width as shown attachment.
- wandererfan
Seems to be a bug for Edge to Edge Horizontal Distance dimensions. There are a couple of alternatives you can use until it is fixed:jaisejames wrote:Unable to create total length or width as shown attachment.
Except edge to edge, all selection are working. But if any changes made in part model after adding dimensions, freecad crashes.
If I delete all drawing sheet, further changes made in part model work again.
Deleting also should be top to bottom say first delete page, then all other views one by one. If not, freecad crashes.
Any one having same issues?
OS: Ubuntu 16.10
Version: 0.17.8675 (Git)
Build type: None
Hash: 33c7ec80c86d668fab33615483f1423ab0cd2f37
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
It will nice have - if page deleted, all content also deleted.
It will nice to option to add caption below view like in latex & option to create standalone isometric view same like 3 view [large drawing one view will be one page].
OS: Ubuntu 16.10
Build type: None
- wandererfan
Are your dimensions "Projected" or "True"? If they are "True" (linked to 3D model) then they are subject to the "topological naming" problem. Shouldn't crash though. Do you have a sample file and step by step instructions to create the crash?jaisejames wrote:Except edge to edge, all selection are working. But if any changes made in part model after adding dimensions, freecad crashes.
Best practice for now is to leave True dimensioning to the end of the process when the model isn't changing much.
I usually delete bottom-up - delete the children, then the parent. Are you saying that deleting a child causes a crash?jaisejames wrote:If I delete all drawing sheet, further changes made in part model work again.
I've been working on this problem for a long time, but haven't been able to solve it yet.jaisejames wrote:It will nice have - if page deleted, all content also deleted
I like the idea of a caption that stays visible vs the Label which comes and goes with the frame.jaisejames wrote:It will nice to option to add caption below view like in latex & option to create standalone isometric view same like 3 view [large drawing one view will be one page].
You can create a single iso view, but it is a bit irritating. You need to fiddle with the XAxisDirection to get the view rotated properly. Working on making this friendlier.
Thanks for the feedback.
wf
