Hello everyone,
I just ran into an issue originating from this commit from 3 weeks ago. I wanted to rotate an object 180° around the y-Axis which I could not do because the "pitchAngle" spin box is now limited from -90° to 90°. I see the reason for having sensible limits to inputs the user can make, however in case of angles 180° is definitely a valid angle, so is 360° and everyting above. If a user wants to rotate an object 720° just let him
I suggest removing the limits completely. If that is not an option for you guys I would suggest to at least change them for all axis to -360° to 360°.
(Btw. is this the correct place for this post?)
Thank you all for the amazing work!
jffmichi
[solved] Range Checks in Placement Dialog
- adrianinsaval
Re: Range Checks in Placement Dialog
According to the German wikipedia yaw and roll are defined in the range ]-PI, +PI] and pitch in the range [-PI/2, +PI/2]. And this makes sense because when computing the yaw, pitch, roll angles from a given quaternion then arctan and arcsin are needed which return angles in the above mentioned ranges.I just ran into an issue originating from this commit from 3 weeks ago. I wanted to rotate an object 180° around the y-Axis which I could not do because the "pitchAngle" spin box is now limited from -90° to 90°
By allowing arbitrary input angles it cannot be guaranteed that the computed angles from a quaternion will be equal and this can cause weird side-effects when working with expressions. For more details see: https://forum.freecadweb.org/viewtopic.php?f=3&t=72522 (especially https://forum.freecadweb.org/viewtopic. ... 05#p648305)
But the placement dialog isn't the only dialog where we restrict the input angles. You will see them also for the revolution/groove or primitive creation dialogs.I see the reason for having sensible limits to inputs the user can make, however in case of angles 180° is definitely a valid angle, so is 360° and everyting above. If a user wants to rotate an object 720° just let him
Either we leave it as it is and avoid the side-effects or remove the restrictions but then cannot handle the side-effects.I suggest removing the limits completely. If that is not an option for you guys I would suggest to at least change them for all axis to -360° to 360°.
I did not know about that thread and will read through it and see if I can understand the implications.
However, I do still think that "rotate an object 180° around the y-axis" is an operation that the Placement dialog should support by entering 180° in the "around y-axis" text field. Otherwise a user needs to do the mapping to yaw-pitch-roll ranges in their head and enter yaw: 180°, pitch: 0°, roll: 180° to get the desired orientation. Even for something simple als 180° this is unpractical at least in my head.
Personally and for this use case I would be ok with the Placement dialog then showing 180°, 0°, 180° when I open it the next time
OK I read through the thread. I still stand by my statement that "rotate 180° around y-axis" should be possible without converting in your head. I noticed I can still do that by using "Rotation axis with angle" and manually entering (0,1,0) as axis... a few more keystrokes but somewhat acceptable. Maybe I'll try using the "Transform"-thingy.
In any case, I'm not perfectly happy with the range check but if that solves another problem I'll live with it happily ever after.
Thank you for the awesome work you all put into FreeCAD!
jffmichi
jffmichi
