More ideas for minor UI tweaks.
MisterMaker
Post by MisterMaker »
First one:
Turning the currently workbench toolbar that is in Linkstage in a overlay and turn it into a dock, just like we have on the mac and on some Linux systems. Probably not so hard to do for @realthunder :)
docks small.png (770.97 KiB) Viewed 1342 times
Second grouping the Property view and the selection view into pull down menu's instead of tabs.
And/or using side tabs that let you open these panels on the go, this as an alternative too the autohide function in Linkstage.
Example from Ms Code.
adrianinsaval
Re: More ideas for minor UI tweaks.
Post by adrianinsaval »
I like the idea of an overlayed toolbar, regarding data and view properties grouping i actually prefer the tabs, much easier to switch from one to the other. A sidebar to control active panels is also a good idea IMO.
MisterMaker
Can probably do the sidebar with just macro buttons, I'll try tomorrow.
MisterMaker
Got it too work with custom icons, although no fancy ones just simple letters.
Demonstration here:
https://twitter.com/MisterMakerNL_/stat ... 0869583872
Macro's below with icons.
Macro.zip
(71.18 KiB) Downloaded 45 times
