ExtremeProDark
Re: ExtremeProDark
Post by Kunda1 »
Can you open a ticket on the FreeCAD Addon repo with the appropriate fix that way we can signal all the theme authors conveniently. TIA
MisterMaker
Re: ExtremeProDark
Post by MisterMaker »
It's in the addon browser!
Please try it!
MisterMaker
Re: ExtremeProDark
Updated for the slider issue that @sliptonic mentioned and @Syres was kind enough to fix.
Also cleaned up a LOT, was working on a light theme but therefore I had to clean up the dark theme first.
Hopefully you don't even see it... :lol:
Except I made the current active text box dark purple so it stands out a bit more, also fixed a nasty bug there.
MisterMaker
Re: ExtremeProDark
So I was working on my Extreme pro dark theme.
Got frustrated that I wasn't able to fix a issue.
Also so many fixes in the code gathered by years of development.
And I ended up throwing the code in the bin and downloading a fresh and clean dark theme.
Need some small fixes but already got more out of it than my original theme.
https://github.com/MisterMakerNL/Freeca ... evised.qss
MisterMaker
Re: ExtremeProDark
Updated it, fixed all bugs I could find. The drop down icon only works good in dev .21 and in 20.1 it's a bit small.
Could use some linux testers!?
I was thinking about replacing the ExtremeProDark theme with this code. But I think I am going to remove ExtremeProDark and rename it since it has only the colors in common now.
There are a some bugs in my ExtremeProDark, but a lot more in the Prodark version I think it would be smart to add note the freecad version it was designed for in the addon manager.
MisterMaker
Re: ExtremeProDark
I pushed the new code to this repro.
It turned out to be a bit more bland dark theme, but I fixed a lot of issues and bugs.
You cannot change the link color, which is blue as you see on the screenshot, and it's a pretty important thing to read. So I made the background a lot lighter than I wanted. But now it is at least readable.
There are probably some bug left but it's a lot better than anything else dark theme out there.
Re: ExtremeProDark
Post by Kunda1 »
MisterMaker wrote: Mon Sep 19, 2022 8:40 pm You cannot change the link color, which is blue as you see on the screenshot
I thought we made it possible to do so? Trying to find that discussion with chennes in the forum somewhere...
MisterMaker
Re: ExtremeProDark
@Kunda1
Thanks, found the thread also reported it broken :)
Re: ExtremeProDark
Post by Kunda1 »
MisterMaker wrote: Tue Sep 20, 2022 1:20 pm Thanks, found the thread also reported it broken :)
URL for posterity ?
MisterMaker
Re: ExtremeProDark
Older thread.
https://forum.freecadweb.org/viewtopic.php?f=34&t=50744
Waiting now if someone reacts otherwise I'll make an issue on github.
