AFAIK is it possible to split the combo view to have the tree view and the property editor in separate widgets. I can not find how to do this. Does someone has more information about this.
cheers bernd
split comboview, show tree and property editor separately
- adrianinsaval
Re: split comboview
edit->preferences->general->tree view mode->tree view and property view (or the both option if you still want them in combo view too)
then restart freecad go to view->panels and check the tree view and property view
Re: split comboview
No, that's not possible. The combo view internally uses a tab widget where on the first page a splitter (see QSplitter) is used that keeps the tree view and the property editor. So far this class doesn't offer a way that you could drag and drop widgets from/to it.
Re: split comboview
very cool, long tree and all attributes are visible, really cool ...adrianinsaval wrote: ↑Thu Oct 28, 2021 6:28 pm edit->preferences->general->tree view mode->tree view and property view
Re: split comboview
May be my question was expressed bad. The pref above was what I was looking for.wmayer wrote: ↑Thu Oct 28, 2021 7:43 pmNo, that's not possible. The combo view internally uses a tab widget where on the first page a splitter (see QSplitter) is used that keeps the tree view and the property editor. So far this class doesn't offer a way that you could drag and drop widgets from/to it.
- Shalmeneser
Re: split comboview, show tree and property editor separately
But why the Theme is not supported when undocked ?
- Capture du 2021-10-29 11-05-21.png (30.1 KiB) Viewed 2854 times
