Light Icons for Dodo Workbench
TerenceL
Post by TerenceL »
Got to say thanks to all the developers. These new dark themes, are really great! I was beginning to use the Dodo workbench a lot, but i find it hard to see the icons if a dark theme is used. Attached are "light" versions of the icons, if anyone is interested. Please make a backup of your existing set, before extracting the zip file into your /Mod/dodo/iconz/ folder.
Original Icons
Original Icons
Light Icons for Dark Themes
iconz_DodoLightIcons_svg.zip
Light Icons for Dodo WorkBench
(176.16 KiB) Downloaded 77 times
regards
-T
Re: Light Icons for Dodo Workbench
Post by Kunda1 »
Please also open ticket on the Dodo workbench issue queue on github https://github.com/oddtopus/dodo/ so that @oddtopus and others are aware of this FR.
Edit: clarification/grammar/typos
mwlandolsi
Post by mwlandolsi »
Here is my contribution for icons design.
In this set, I tried to respect the original colors as mach as possible.
With this set, it is possible to see icons clearly both in dark and light thems.
Screenshot from 2022-07-17 16-43-45.png (91.42 KiB) Viewed 1509 times
Screenshot from 2022-07-17 16-43-12.png (87.15 KiB) Viewed 1509 times
just download and place these icons int the right module path
for Ubuntu Linux 22.04 users place them at /home/[user]/snap/freecad/common/Mod/dodo
for other OS try to find the module folder location ../Mod/dodo
iconz-dark-light.zip
(378.59 KiB) Downloaded 48 times
Post by Kunda1 »
CC @oddtopus check this out :D
Very nice! @mwlandolsi are you planning to make a code submission to dodo workbench code repository ?
Edit: created https://github.com/oddtopus/dodo/issues/15
mwlandolsi
Kunda1 wrote: Mon Jul 18, 2022 2:14 am CC @oddtopus check this out :D
I do not know if my post in GitHub in the above link is sufficient, or should I do something else ?
Post by Kunda1 »
If it's to get merged then i assume some logic would need to coded to allow the user to choose which icon set through an interface of some sort..? or did you already propose that?
MisterMaker
Post by MisterMaker »
Wow nice more icons!!! The first one already looked epic but the second with all the colors sweeeet!
You can btw use the icon theme workbench it still works. Especially if you have svg files!
mwlandolsi
Kunda1 wrote: Mon Jul 18, 2022 1:05 pm If it's to get merged then i assume some logic would need to coded to allow the user to choose which icon set through an interface of some sort..? or did you already propose that?
I think that no extra coding is necessary. The same Icons are graphically designed to be clearly visible on both dark and light themes.
