[Merged] Surface Workbench icons improvement
bitacovir
Post by bitacovir »
This thread is to propose better colors for Surface Workbench icons https://wiki.freecadweb.org/Artwork_Surface
This is a request done in this post https://forum.freecadweb.org/viewtopic. ... 88#p436293
I will come with some options in the next post.
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
bitacovir
Re: Surface Workbench icons improvement
Post by bitacovir »
Here a first approach with an orange color.
::bitacovir::
carlopav
Post by carlopav »
My 2 cents: Artwork are nice, but i think they should stay Blue. Cause Blue Is the Part color and so should be for all objects that produce an OCC Shape...
It's pointless ti distinguish them by workbench, since only one workbench Is activated at once...
vocx
Post by vocx »
bitacovir wrote: Thu Oct 08, 2020 2:39 am Here a first approach with an orange color.
Wow! It looks nice, but being honest I also think it is a bit "loud" when you combine it with light greens and blues. Personally, I would prefer more sober tones, like blue or purple.
Like Carlo said, I also thought about using the Part-blue, however since the original XPM icon of the workbench had a light blue/rose tone, I decided to use violet as my main color.
I'm not opposed to using the Part-blue in all icons, however I found it a bit boring and repetitive, so I wanted to try something new.
Essentially everything in FreeCAD generates OCCT shapes, however I don't think everything has to be the same color; in fact, each of our current workbenches have a dominant color already, Part and PartDesign are blue, Sketcher red, Draft yellow, Arch yellow-white, Path green-grey, etc. So, I thought that maybe Surfaces can have a purple tone, but orange (dark orange preferably) is still on the table.
bitacovir
Post by bitacovir »
vocx wrote: Thu Oct 08, 2020 5:02 am
But, we don't have violet in the FreeCAD Palette https://wiki.freecadweb.org/Artwork_Guidelines
So. Is Sky Blue ok?
Ok. Carlopav, but remember that Arch and BIM both integrate several WB tools.
::bitacovir::
vocx
Post by vocx »
bitacovir wrote: Thu Oct 08, 2020 5:33 pm But, we don't have violet in the FreeCAD Palette https://wiki.freecadweb.org/Artwork_Guidelines
Indeed, we don't have violet in the FreeCAD palette, but frankly, we don't follow completely those guidelines. Who says we can't add a couple more colors to FreeCAD? There is nobody truly enforcing those rules but ourselves.
I like the blue color, but it's not very easy to distinguish which is the point on the curve and which is the handle. Maybe one (circle or square) should be orange, and the other should be a different color.
bitacovir
Post by bitacovir »
vocx wrote: Thu Oct 08, 2020 8:22 pm
What about this?
::bitacovir::
vocx
Post by vocx »
bitacovir wrote: Sat Oct 10, 2020 5:32 pm What about this?
Can the green be a bit darker, or the fill not white? As I said, I'm not super happy about the light colors. The design looks good, I think choosing the colors is a bit of fine tuning and personal preference.
If I design icons I also compile the software with them to see how they look in the real interface. This gives me a better feeling than just looking at the icons in isolation.
bitacovir
Post by bitacovir »
vocx wrote: Sat Oct 10, 2020 10:54 pm
Here with green in the fill. (I liked white more because gives a better defined point).
::bitacovir::
vocx
Post by vocx »
bitacovir wrote: Sun Oct 11, 2020 6:57 pm Here with green in the fill. (I liked white more because gives a better defined point).
Looks nice.
