A few paid commits for FreeCAD
Post here if you have a FreeCAD-related job to offer to the FreeCAD community. This can include programming or modeling.
Roy_043
Re: A few paid commits for FreeCAD
Post by Roy_043 »
NewJoker wrote: Wed Oct 26, 2022 11:42 am - adding the possibility to define keyboard shortcuts for Draft snaps (for some reason they were overlooked):
With https://github.com/FreeCAD/FreeCAD/pull/7656 shortcuts can be assigned to Draft snaps. But using them during a command only works if the input boxes do not have the focus as they 'catch' the so-called in-command shortcuts (while creating a Draft_Wire in the 3D view the X input box will have the focus).
NewJoker
Post by NewJoker »
Roy_043 wrote: Mon Oct 31, 2022 7:55 am With https://github.com/FreeCAD/FreeCAD/pull/7656 shortcuts can be assigned to Draft snaps. But using them during a command only works if the input boxes do not have the focus as they 'catch' the so-called in-command shortcuts (while creating a Draft_Wire in the 3D view the X input box will have the focus).
Thank you for letting me know about this. It's available in the newest Windows build so I tested it. It's a really good start but would it be possible to code it in such a way that it works also when focus is on the input boxes (so that it's not necessary to click on the background of the task panel to unfocus) ? This could improve the Draft workflow significantly.
P.S. I added this to the release notes.
Roy_043
Post by Roy_043 »
You can remove the focus from the X input with Shift+Tab and then enter a shortcut. You need to keep the mouse steady while doing this though.
NewJoker
Post by NewJoker »
Roy_043 wrote: Thu Nov 10, 2022 8:29 pm You can remove the focus from the X input with Shift+Tab and then enter a shortcut. You need to keep the mouse steady while doing this though.
Good to know that. Would it be possible to change this Shift+Tab combination to a single key ? So for example one would have to press Shift (or other button like this) to unfocus plus snap button (like N for near) right after that to enable the snap.
galou_breizh
Post by galou_breizh »
NewJoker wrote: Wed Oct 26, 2022 11:42 am - adding selection filter for Part/PartDesign (the code already exists in the Assembly 4 module and it's just a matter of transferring it to Part/PartDesign):
https://forum.freecadweb.org/viewtopic. ... 3&start=10
This was also already done by user
realthunder wrote:
in his Link3 branch.
