Is there a possibility to simulate a trajectory in joint space as opposed to Cartesian space with the Robot Workbench?
I can "move" the robot by giving its joints' values and then create a waypoint but this waypoint is saved as Cartesian co-ordinates of the TCP.
Trajectory in joint space with the Robot Workbench
Re: Trajectory in joint space with the Robot Workbench
No, the trajectory is only Cartesian...
Stop whining - start coding!
the question is interesting though; could you perhaps tell us where to look in the source code to use the tool coordinate system rather than the cartesian?
i'd like to look into this...
I didn't work much with the robot module so far but I think the code you're interested in is the method Robot6Axis::setTo() under src/Mod/Robot/App/Robot6Axis.cpp line 235.
As argument this method accepts a placement (which is basically a rotation and translation) and here it uses the KDL classes ChainIkSolverVel_pinv and ChainIkSolverPos_NR_JL to convert the Cartesian placement information into joint space.
For the usage of Robot6Axis see also into RobotObject.cpp and Simulation.cpp.
I hope this helps you.
Cheers
Cheers
What he ment is not the Tool (which is defined in the 6AxisRobotObject), rather to define a trajectory in joint space which mean to give each point in time and space
by the position of all 6 Robot axis. Thats clearer (cause every Cartesian position has potentially 6 solutions in joint position) but makes the
trajectory robot and position Dependant (whats no good)....
Actually, in the general case, the inverse kinematics of robots with 6 axes have a maximum of 16 solutions, in non-singular positions. Robots of type 6R (6 revolution axes) with 3 intersecting revolute axes have a maximum of 8 solutions (this is the case of common industrial robots with a wrist).
For non-singular positions, it would be nice to have the possibility to choose between the available solutions. Are they available when using KDL?
A trajectory defined in joint space allows a full control over the situation of the robot. A robot with more or less than 6 axes could also be simulated in this way.
Werner, what do you think of the idea to implement a new type of object for this situation, named for example "Robot::JointSpaceTrajectory"? I would be glad to give a hand.
KDL uses a newton solver for IK. That gives you only the next best position but allows simulation of any type kinemematik.For non-singular positions, it would be nice to have the possibility to choose between the available solutions. Are they available when using KDL?
