Unable to create 2D drawing from 3D part
I created a fancy little part in 3D, called MyBracket (attached). I want to put it into 2D on a drawing. Here is the process I am going through.
1. Click Drawing > Insert new drawing > A4 Landscape.
2. Select the part in the Combo View panel that I want to put in the drawing.
3. Click Drawing > Insert orthographic views.
4. From the Tasks tab, choose the projection and views that I want, sending click OK.
When I do this, I get a blank page (See attached). What am I doing incorrect, and how do I do it correctly?
- Screenshot
- untitled-1.png (206.55 KiB) Viewed 2599 times
- MyBracket.FCStd
- 3D part
- (85.07 KiB) Downloaded 42 times
Re: Unable to create 2D drawing from 3D part
Hello onebigfish,
The file you attached does not contain your drawing template nor the views you created. Your screen capture shows you created a custom template. The problem is quite probably there.
Have you tried changing the template to one provided with FreeCAD? (You can do that on its properties in the Data tab) Does it show the views?
When creating your template, have you followed the Drawing Template HowTo? You need to insert some code in the SVG and that has to be done with a text editor.
I tested with the A3_Landscape.svg template, and views of your model are shown on the page as expected.
Version used:
OS: Windows 7
Word size: 64-bit
Version: 0.14.3700 (Git)
Branch: releases/FreeCAD-0-14
Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1
Python version: 2.7.6
Qt version: 4.8.5
SoQt version: 1.6.0a
OCC version: 6.6.0
Version used:
OS: Windows 7
Word size: 64-bit
Qt version: 4.8.5
OCC version: 6.6.0
I tried it with A4 and didn't have any problem either.
1. Downloaded your file and opened it in FreeCAD.
2. Changed to the Drawing WB and clicked the A4 Landscape icon:
This created a new drawing page, and the graphics window updates to display it.
3. In the tree view I selected "Cut010" by clicking on it.
4. I clicked the Orthographic Projection icon:
5. Then selected the top and right views to add them too, and it looks like this:
So maybe you deleted the Page folder by mistake?normandc wrote:The file you attached does not contain your drawing template nor the views you created.
- 20141106b_bracket.fcstd
- (92.17 KiB) Downloaded 42 times
Yes, I did create a custom template in Illustrator. I did not know there was any special requirements for it. I will follow the instructions on the link and see what I can do. I see that others are able to create it, so it must not be the 3D source file that is the problem.
Thanks!
Thanks!
Sense you already have the "artwork" down, I would start here - Once Your Template Is Made - You do not need to input the Border and Tilte Block defines, but they sure are nice, and it might be good practice to do so. If you want editable text, following the directions in the How To is a must.onebigfish wrote:Yes, I did create a custom template in Illustrator. I did not know there was any special requirements for it. I will follow the instructions on the link and see what I can do. I see that others are able to create it, so it must not be the 3D source file that is the problem.
Thanks!
The one thing you absolutely must have in in the SVG template for it to work with FreeCAD is - The DrawingContent Tag - Without it, FreeCAD has no way of knowing where to insert any new information into the document. This is the one thing that is stopping you from adding your views to your template.
Mark
Mark
It worked, thanks!
This might be a dumb question, but how do you edit the text in the title block once it is in FreeCAD? I followed the instructions for creating the template, so I have the freecad:editable in the file, but I cannot find a tool for editing the text.
Once you have loaded your Template, select it in the tree view and click on the Data tab. There you will find the editable text. Click on it and you will then see the little [...] button on the left, Click it and you will be presented with an Edit dialog.
Mark
Mark
OS: Mac OS Xquick61 wrote:Once you have loaded your Template, select it in the tree view and click on the Data tab. There you will find the editable text. Click on it and you will then see the little [...] button on the left, Click it and you will be presented with an Edit dialog.
Mark
What I'm working with.
Word size: 64-bit
Version: 0.14.3703 (Git)
Hash: c6edd47334a3e6f209e493773093db2b9b4f0e40
Python version: 2.7.5
Qt version: 4.8.6
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0
I have created a title block in inkspace and followed the FC tute on editable text but I do not understand how to access the editable fields. {Quick61} screen shot is different to mine.
I am totally new to FC.
Attached is my title block, I have gone over and over it for syntax errors (from a newbs perspective). So I think it is just a case of not knowing 'ALL' FC workflow/steps to reveal them in the Tree view.
My desire is to use the template for importing the contour maps/orthos, DEM's from our UAV. Then print as a pdf.
1. I hope you can help.
2. I hope doing this FC title block approach works for me.
Thanks in advance.
Troy
- RPAS_2_A4.svg
- Title block A4
- (97.84 KiB) Downloaded 197 times
