Parametric face out of two draft wires
hko
Post by hko »
Let's say I have two draft wires, both of which are not closed, but together form a closed wire. I can't use Draft_Join to join them because I need them as separate wires (the other one is a base wire for a wall).
Is there a way to create a parametric face out of those two wires?
I could use Part_Builder, select all the edges of those wires and create a face, but it wouldn't be parametric (if I move points of the wires, for example, I need to recreate the face).
Part_MakeFace would create a parametric face out of a single closed wire but doesn't accept two open wires. I could use that if I could create a parametric combined wire out of the two wires but I haven't found a way to do that either.
OS: Ubuntu 20.04.5 LTS (KDE/plasma)
Version: current master branch as of this writing, see hash
Build type: Debug
Hash: 633a6e825ca37cc7111fbfa8d7a53ec23e1c29bd
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.3.0
Installed mods:
  * dodo 1.0.0
  * BIM.backup1663296114.5945559
  * Help 1.0.3
  * BIM 2021.12.0
Vincent B
Re: Parametric face out of two draft wires
Post by Vincent B »
Need the file.
onekk
Post by onekk »
hko wrote: Sat Jan 28, 2023 2:02 am ...
"A face is a portion of a surface limited by a wire".
From the definition is not possible to have an unclosed wire to "limit something" it is basic Topology. See maybe in wiki what it means.
You could probably create copy of the two wires and join them.
Workflow is not very clear however.
Posting a file probably will help as an helper could ipen the file and see what is wrong and maybe even supply a new file with s solution.
Regards
Carlo D.
- Various other stuffs.
You can use a SubShapeBinder. If it is not "face enough" for whatever you intend, use a FaceBinder on top of the SubShapeBinder.
unconnectedParametric.FCStd
(8.87 KiB) Downloaded 11 times
hko
Post by hko »
chrisb wrote: Sat Jan 28, 2023 9:52 am You can use a SubShapeBinder. If it is not "face enough" for whatever you intend, use a FaceBinder on top of the SubShapeBinder.
Thanks, SubShapeBinder (alone) works probably fine. It can be extruded, for example.
In your example the Support of Binder includes the edges of the Wire and the only edge of Line, which means that Binder needs to be manually updated if points are added to/removed from the Wire. But it seems that one can use Wire and Line directly as the Support, which solves that "problem". Wonderful!
