[BUG]Macroeditor doesn't accept serveral letters
strahlensauger
Post by strahlensauger »
when I open the Macroeditor I cannot write the letters
wertzvb
I get a
'failed to create compose table'
error
in older versions everything worked fine.
This error occurs not only on my main production machine but also
on another PC running debian.
Is this a bug already known?
Thanks
OS: Arch Linux (KDE/plasma)
Version: 0.21.0.31695 (Git) AppImage
Hash: 64caea207394bb05587c8ffb29b7a3e8696d24df
Python 3.10.8, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Installed mods:
  * Assembly4.backup1662658912.4353526
  * Behave-Dark-Colors 0.1.1
  * Behave-Dark-Colors.backup1662668082.023044
  * Assembly4 0.12.4
  * FeedsAndSpeeds 0.5.0
  * freecad.gears 1.0.0
  * A2plus 0.4.60e
  * A2plus.backup1662291454.6363213
Re: [BUG]Macroeditor doesn't accept serveral letters
I cannot confirm. Does it occur on newly created or existing macros?
strahlensauger wrote: Fri Jan 27, 2023 10:10 pm in older versions everything worked fine.
Please add the last version known to work.
OS: macOS 10.16
Version: 0.21.0.31641 (Git)
Hash: d28d63b87b60161419c6c0c532fbbfaed96926b8
Locale: C/Default (C)
Installed mods:
  * FC_SU
  * DynamicData 2.46.0
  * dxf-library
  * fcgear 1.0.0
  * fasteners 0.4.54
  * sheetmetal 0.2.60
  * ExplodedAssembly
  * Curves 0.6.5
strahlensauger
The last known working version is 31513.
Version 316142 is the first version not working. (I dont know if there are versions inbetween)
I use the Appimage for Linux.
The error occurs in the Macro editor, no matter if it is a newly created macro or an existing one.
I can check when the next version comes out, probably tomorrow. Please correct the number 316142. It's not clear which of the last three digits is/are wrong.
strahlensauger
Sorry my bad, it was 31641.
Thanks for your assistance.
I just setup an old laptop with opensuse leap, just to check.
The error 'failed to create compose table' appeared, but it accepted
all letters from the keyboard.
Pretty weird...
So it is indeed supposed to work in my version. I will recheck as promised.
drmacro
Post by drmacro »
Seems ok in 31702, Debian 11.
strahlensauger
In the arch linux OS the error still persists with the newly released
FreeCAD 31709. Debian is OK, opensuse Leap throws still an error message
but works. Because of the Appimage I think
missing packages could not be the reason for that, also
everything worked fine in versions prior to 31641..
strahlensauger
Doesn't work even on a fresh arch installation and also in the python console
the same letters are ignored.
Because I experience this error on multiple arch machines, I guess everybody
with an arch linux OS should have the same problems.
Worth a bug report?
openBrain
Post by openBrain »
strahlensauger wrote: Mon Jan 30, 2023 4:37 pm Doesn't work even on a fresh arch installation and also in the python console
Worth a bug report?
Could you please give output of
locale
command entered in your OS console ?
