[Solved] Double offset followup
jfc4120
Post by jfc4120 »
OS: Windows 10 Version 2009
Version: 0.20.2.29177 +426 (Git)
Branch: (HEAD detached from 0.20.2)
Hash: 930dd9a76203a3260b1e6256c70c1c3cad8c5cb8
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Installed mods:
  * Help 1.0.3
I have been trying to use sketches to accomplish this, see:
https://forum.freecadweb.org/viewtopic. ... 42#p609342
@domad reply.
Seems you have to use part first to get the compound miter angles, or how would it be done in sketcher? I can do this in part, but not from sketches.
The image shows what I am after. But when I do additive loft in part design, it gives the wrong result.
Any help resolving this would be appreciated.
What I am after
What I am after
What I get
What I get
Sketches
Sketches
offset_sketch.FCStd
(24.01 KiB) Downloaded 13 times
jfc4120
Re: Double offset followup
Post by jfc4120 »
I discovered I can also use 4 wires. End wires and the two compound miter wires and use part loft between 2 wires at a time.
But after 20 attempts I cannot figure out how it's done in part design using sketches.
offset_loft.FCStd.FCStd
(27.84 KiB) Downloaded 11 times
drmacro
Post by drmacro »
There are things that work in Part workbench and don't in Part Design.
Nothing wrong with doing it in Part workbench.
jfc4120
Post by jfc4120 »
@drmacro thanks for the reply.
jfc4120
Post by jfc4120 »
I am at the point where 3 sketches work, but all 4 does not work, images included. Drawing also included.
I can do a final loft on last two. But no matter what I try, 4 sketches will not properly loft.
offset3d_part_design2.FCStd
(64.01 KiB) Downloaded 12 times
You cannot control the mapping of the edge segments directly. Use intermediate sections if you get unwanted crossings.
jfc4120
Post by jfc4120 »
@chrisb Thanks for the answer. I did that and it worked. But thanks for clearing it up.
And if I haven't already, I appreciate the mini tutorial you gave in sketcher in the other post. :D
Referring to https://forum.freecadweb.org/viewtopic. ... 55#p655155
I know just that short tutorial will help anyone new to Freecad. I've been mostly using draft, but recently using sketcher more for some things.
