Hello everyone, I am trying to test performance FreeCAD to use it in a future project, but I will need to work with at least 20000 *lines and others objects for MEP design (pipes, panels, valves, etc).
Anyone knows how can I optimize FreeCAD? I have problems only using 4 nested arrays.
edit1: actually FreeCAD in my PC can manage around 1000 elements, this is ideal for Arch Struc or Mech, but in MEP the elements are exponential, but generally Lines.
FreeCAD performance for MEP
- performance MEP test1.FCStd
- (12.37 KiB) Downloaded 21 times
Re: FreeCAD performance for MEP
5 nested array with 8 elements each. 8^5 = 32768 identical elements. The copied element has 7 edges. 32768*7 = 229375 edges. And that is just counting the final array.
Why/how is this a realistic benchmark?
I made a macro that worked well with piping. I haven't touched it in a while, it could be a good start for something.
https://forum.freecadweb.org/viewtopic. ... 20#p595044
- thomas-neemann
i would convert it to stl. here are examples
https://forum.freecadweb.org/viewtopic. ... 55#p413755
https://forum.freecadweb.org/viewtopic. ... 38#p414438
after many test I found similar performance between FreeCAD and AutoCAD.
