Partdesign Groove Issue
pschindler
Post by pschindler »
I am currently working on more complicated parts with a number of spherical surfaces. Unfortunately, I seem to be running into some difficulties / limitations of FreeCad during my work on these kind of geometries. I compiled a minimal example which shows my problem. I have a PartDesign Body with two Features (Revolution A, and Groove B). I want to use a 360° (through all) angle for feature B, but as soon as the angle is increased above a certain threshold the feature just stops working. Any ideas on what is wrong and what I could try instead would be highly appreciated.
OS: Ubuntu 22.04.1 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.1.29410 (Git) AppImage
Branch: (HEAD detached at 0.20.1)
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
SphericalGeometry.FCStd
(27.91 KiB) Downloaded 22 times
Screenshot from 2022-11-28 15-43-55.png (185.39 KiB) Viewed 601 times
Screenshot from 2022-11-28 15-44-30.png (228.45 KiB) Viewed 601 times
onekk
Re: Partdesign Groove Issue
Post by onekk »
pschindler wrote: Mon Nov 28, 2022 2:47 pm ...
It is perfect correct, you have not enough solid to do a groove of more than certain degree in the axis you want.
You have two sketch perpendicular one to another.
I could extend Revolution to 360 degree without problems, but "Groove B" is in the perpendicular axis, so the solid end before your "desired" degree is reached.
This is around 28 degree in Groove B and it is very near the border of "Revolution A" of 360 degree.
It is not clear what you want to achieve.
Regards
Carlo D.
- Various other stuffs.
domad
Post by domad »
pschindler wrote: Mon Nov 28, 2022 2:47 pm ....
Hi pschindler, hello to the Community!
If I have interpreted your request correctly you should change the axis of revolution of "Revolution A" from "Horizontal Sketch axis" to "Base Y axis". ;)
pschindler
Thanks for your quick responses, this is amazing!
Here is another image to more clearly illustrate what I want to achieve.
Basically with the Groove B I want to remove all of the material within the area marked in green, please the the newly attached image.
Screenshot from 2022-11-28 19-18-38.png (291.31 KiB) Viewed 506 times
edwilliams16
Post by edwilliams16 »
First, I should congratulate you on a model (first!) post - full FreeCAD info., a simplified model and a full description of the problem.
domad wrote: Mon Nov 28, 2022 5:15 pm
That indeed works, but I'm unclear on why "Horizontal Sketch Axis" causes problems later in the model. SketchA is attached to the YZ_Plane, so "Horizontal Sketch Axis" and "Base Y Axis" should be the same. What am I missing?
pschindler
The Groove B (Green Sketch) should be rotated around the Horizontal Sketch Axis, which corresponds to the "Base X axis".
(Revolution A (Yellow Sketch) should be rotated around the Horizontal Sketch Axis as well, which in this case corresponds to the "Base Y axis".)
pschindler
edwilliams16 wrote: Mon Nov 28, 2022 6:23 pm
Sorry I didn't get what you mean at first. English is not my first language.
Indeed "changing" the rotation axis of Rotation A Feature makes the Groove B Feature work, although the axis after changing actually are identical.
Thanks so much, I will see if this also works in my more complicated model.
Here is the result I wanted to have, still wondering why it works now, but not before ;)
Screenshot from 2022-11-28 19-55-41.png (223.49 KiB) Viewed 462 times
pschindler
Thank you so much for this fix. I would have never checked that setting. I made a follow-up post (https://forum.freecadweb.org/viewtopic.php?f=3&t=73986) on a slightly more complex part. There your approach unfortunately does not work. Maybe you have another amazing idea there as well ;)
