[SOLVED] - Trouble referring expressions
Lonfor
Post by Lonfor »
I renamed an angular constraint in order reuse it in other sketches. I followed the instructions at https://wiki.freecadweb.org/Expressions but it looks like I have a comprehension problem or there is something wrong with the notation.
What I need is to link, or reference, the expression named "60grados" in the same sketch, in other features in the same file, and also in other files.
Can you tell me please what is the right notation for to do those three tasks?
OS: Debian GNU/Linux 11 (bullseye) (KDE/plasma)
Version: 0.20.1.29410 (Git) AppImage
Branch: (HEAD detached at 0.20.1)
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Installed mods:
  * CurvedShapes 1.0.4
  * Manipulator 1.4.9
  * Help 1.0.3
  * Assembly3 0.11.4
  * Curves 0.6.1
  * toSketch 1.0.1
  * QuickMeasure 2022.10.28
  * A2plus 0.4.60b
  * Assembly4 0.12.4
  * offline-documentation 1.0.0-alpha
  * fasteners 0.4.22
Cropped - Expressions.jpeg (125.25 KiB) Viewed 281 times
Cropped - Expressions2.jpeg (398.29 KiB) Viewed 281 times
Re: Trouble referring expressions
The name must not start with a digit.
Lonfor
Post by Lonfor »
That did the trick.
Also I am noticing that in the Expression Editor dialog, the name of the external file cannot contain spaces, so "caja v2" must be inputed in the dialog as "caja_v2".
Thanks for your help. It is much appreciated. :D
Re: [SOLVED] - Trouble referring expressions
For filenames containing spaces - which I recommend to never use - can be included in expressions by enclosing the filename in double angled brackets, like so:
<<caja v2>>#Sketch. ...
