Duplicating slots
saline
Duplicating slots
Post by saline »
OS: Windows 10 Version 2009
Version: 0.21.31058 (Git)
Hash: e6c53d8642af36ce7d738ab6058b063ec58e0859
Python 3.8.13, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Installed mods:
  * Help 1.0.3
  * sheetmetal 0.2.59
I'm looking for the best way to duplicate slots without having to use the slot feature each time, then having to change all the dimensions. The attached file shows the slots I want to duplicate. I'd like to copy the slot and paste/duplicate it.
Molle.FCStd
(10.04 KiB) Downloaded 16 times
NewJoker
Re: Duplicating slots
Post by NewJoker »
You can use Sketcher RectangularArray tool for this purpose. Or Sketcher Copy.
papyblaise
Post by papyblaise »
there is not a lot of solution, your distribution is something, you can just use the functions "Equal" and construction lines to limit the nb of dimensions to enter
MollePPB.FCStd
(10.07 KiB) Downloaded 10 times
dprojects
Post by dprojects »
You can Copy, Clone or Link any object like this, not only Sketch:
Thanks
Darek
github.com/dprojects
workbench for woodworking is available at: github.com/dprojects/Woodworking
Shalmeneser
Post by Shalmeneser »
Bance
Post by Bance »
Finally a post that contains the required info... :D
What you are looking to do is not the recommended way in FC.
Generally it is better practice to make a simple sketch and propagate through feature patterns.
So given the file it should probably look something like this....
I have not replicated the dimensions exactly rather given indication of how it should be done.
Molle(1Bance).FCStd
(81.64 KiB) Downloaded 13 times
saline
Post by saline »
Excellent! I'm going to try all these, but I have a question. Regarding dprojects' recommendation, how do I get the the magicMove tool bar?
dprojects
Post by dprojects »
saline wrote: Sat Nov 26, 2022 6:36 pm Excellent! I'm going to try all these, but I have a question. Regarding dprojects' recommendation, how do I get the the magicMove tool bar?
This is not released as separate macro, so you have to install the Woodworking workbench from my github directly.
I don't know what you want to do, it is some kind of PCB? So you can create Pad as board and drill holes "slots" with other tool directly.
I am more into "not-bound modeling", less bound objects than better.
phpBB [video]
phpBB [video]
But for regular holes there are other tools:
phpBB [video]
phpBB [video]
Thanks
Darek
