[Solved] Names for faces, edges and vertices?
JussyAD
Post by JussyAD »
Good day
I was just wondering if FC gives unique names for the above for objects? If so, where can one view them because if I select a box's vertex I don't see it in the properties panel?
OS: Windows 8.1 Version 6.3 (Build 9600)
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Locale: English/South Africa (en_ZA)
Installed mods:
  * A2plus
  * BIM
  * CurvedShapes
  * Curves
  * Dracula 0.0.2
  * ThreadProfile
Bance
Re: Names for faces, edges and vertices?
Post by Bance »
You can see it, when hovering mouse or after selection in the Status Bar...
https://wiki.freecadweb.org/Status_bar
openBrain
Post by openBrain »
Also visible in the Selection view
JussyAD
Post by JussyAD »
Many thanks!
onekk
Post by onekk »
JussyAD wrote: Wed Oct 05, 2022 2:16 pm ...
Take note that this is the source of the TNP problem so the unique name is not so robust if the solid is transformed.
See maybe:
TNP Problem
https://wiki.freecadweb.org/Topological_naming_problem
TNP mitigation
https://wiki.freecadweb.org/Feature_edi ... ble_models
Regards
Carlo D.
- Various other stuffs.
onekk
Post by onekk »
JussyAD wrote: Wed Oct 05, 2022 3:15 pmMany thanks!
Please could you delete the duplicated post?
https://forum.freecadweb.org/viewtopic. ... 01#p630801
And maybe if the answers are solving your problem, modify first post title (you could edit it) and add [Solved] at beginning.
Regards
Carlo D.
