Canceling Attachment dialog reverts renaming
This was reported in the German forum: https://forum.freecadweb.org/viewtopic.php?f=13&t=72222.
If an object is renamed in the tree and then the Attachment dialog is opened and cancelled, then the renaming is undone. I cannot provide a file, because the effect vanishes if the file is saved and reloaded.
To reproduce:
- create a cube -> the object is shown as "Cube" in the tree view
- rename it to "NewName" -> "NewName" is shown in the tree view
- click the ...-button of the MapMode's value field to open the Attachment dialog
- cancel the Attachment dialog
-> The name of the object has been reverted to "Cube".
To reproduce:
- Shalmeneser
Re: Canceling Attachment dialog reverts renaming
True
OS: Windows 10 Version 1809
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Locale: French/France (fr_FR)
Installed mods:
* fasteners 0.4.3
* fcgear 1.0.0
* Manipulator 1.4.9
* sheetmetal 0.2.56
It's a regression since v0.20 but worked well in v0.19 and earlier. The funny thing is that when instead of using the renaming function of the context-menu you directly change the label in the property editor it doesn't revert the change when canceling the attachment dialog.
Not exactly (at least here). Actually it appears that if you rename using the Label property in the property editor, the bug will appear 1 time over 2 (very repeatable). Still more fun.
* New document -> Part WB -> Create a Cube
* Select Cube in TreeView
* Change Label in property Editor (let's say "AAA") -> Tab
* Select Map Mode, click the "..." in the value field, cancel Task dialog => OK, Label is "AAA"
* Change Label in property Editor (let's say "BBB") -> Tab
* Select Map Mode, click the "..." in the value field, cancel Task dialog => NOK, Label is "AAA"
Edit : I didn't pull your latest commit yet.
OK, thanks. I can reproduce it.
If you follow your instructions but look at the drop-down menu of the undo actions you will see that after the first renaming there are two actions: the creation and the renaming. If you open and cancel the dialog the first time there are still two actions.
But after renaming the box the second time there is now a third action about editing the attachment instead of editing the label. So, this means that at some point a pending transaction isn't aborted correctly.
That's completely independent to the renaming in the property editor. So, the question is whether it's a problem with the property editor or the attachment dialog.Edit : I didn't pull your latest commit yet.
Great.
I would first suspect property editor, because I already found a regression due to a pretty heavy refactoring of it done by realthunder (I can't remember how old are the commits but I can search for them if needed).So, the question is whether it's a problem with the property editor or the attachment dialog.
This is just feeling though, no technical reason.
Part of the issue is already present in v0.19. After renaming the box the second time there is also the wrong action (about editing the attachment) in the undo list. At least canceling the attachment dialog doesn't revert the renamed object.
In v0.18 all this worked correctly.
