How to get the outline of a solid?
fcbuilder
Post by fcbuilder »
Hi!
I try to get the outline of this solid (the bottom of it), but so far not successful
(Why need the outline? To give the solid a base (a bit different shape (both ends of the shape will be connected
This is my workflow:
1. select the solid
2. use Draft_Shape2DView (Projection Mode: Solid
3. use Draft_Draft2Sketch
A sketch would be created, but it's too detailed. I only want the outline of it.
After I deleted all the lines that I didn't need and extruded the sketch, it failed (sketch validated before
I edited the sketch to be the shape I want but still the same result while extruding it
Btw, it's hard to select the b-splines, and some of them can't to be connected to the lines that I sketched. Is this normal?
I've tried some other ways like offset (first time using 3d but failed too (only a point was created
I selected the outline of the solid manually and use Part_Builder (Face from edges) but failed
I extruded the Shape2DView and the Draft2Sketch created, and both failed (hollow extrude) (desperate attempt...)
So how do you guys get the ouline of a solid?
A faster way would be great (don't want to delete those lines one by one
Preferably to sketch (or draft) (I want the outline able to be edited
Appreciate any help!
OS: GNU/Linux
Version: 0.19
Word size: 64-bit
Release date: 2021/03/17
Python version: 3.9.2
Qt version: 5.15.2
Coin version: 4.0.0
OCC version: 7.5.1
fcbuilder
Re: How to get the outline of a solid?
Post by fcbuilder »
I found a way
I selected the bottom faces of the solid, used Draft_Facebinder (created outline with much fewer lines within), turned the object to sketch with Draft_Draft2Sketch
Then edited the sketch, extruded, and it worked!
Not sure why tho. Maybe the lines created with Draft_Facebinder are fewer than Draft_Shape2DView
Still would like to know how you guys get the outline of a solid
hammax
Post by hammax »
... another workflow => less mess!
FH_Horn_2.FCStd
FC.20.1
(319.96 KiB) Downloaded 6 times
FH_Horn.FCStd
FC.20.1
(38.24 KiB) Downloaded 6 times
