Distance between points/length of a Vector in Formula editor
just_a_dick
Post by just_a_dick »
I've tried to set a sketch Distance constraint to a distance between two datum points, and could not find an elegant way to do it.
There is distanceToPoint Vector method, and if you write
<<Pt1>>.Placement.Base.distanceToPoint
in the Formula editor, it will even say that it is a built-in Python method, but calling it like
<<Pt1>>.Placement.Base.distanceToPoint(<<Pt2>>.Placement.Base)
does not work.
What I currently do is
sqrt((<<Pt1>>.Placement.Base-<<Pt2>>.Placement.Base)*(<<Pt1>>.Placement.Base-<<Pt2>>.Placement.Base))
Is it possible to express this in a more convenient way?
onekk
Re: Distance between points/length of a Vector in Formula editor
Post by onekk »
just_a_dick wrote: Sat Aug 13, 2022 2:17 pm ...
Please add your FC version info:
http://forum.freecadweb.org/viewtopic.php?f=3&t=2264
It could be important to point out what the problem is as FC is evolving and speaking for a 0.20.0 or a 0.19.4 could be different, and sometimes even on different OS as there could be differences in Python versions of OCC versions that could be relevant to correctly answer to your question.
Regards
Carlo D.
- Various other stuffs.
edwilliams16
Post by edwilliams16 »
(<<Pt1>>.Placement.Base - <<Pt2>>.Placement.Base).Length
just_a_dick
edwilliams16 wrote: Sat Aug 13, 2022 5:34 pm
:? Oh, why I didn't try to capitalize the first letter myself…
TYVM!
