Assistance with Mirror and Overall Part Design
mfro
Re: Assistance with Mirror and Overall Part Design
Post by mfro »
thomas-neemann wrote: Sat Aug 06, 2022 7:58 am... but I know of one company that complains about autodesk inventor because you can't create changes in the mirrored half at the sketch level ...
Complaint appears illogical to me.
If you have a mirrored feature, you can't really expect to be able to modify the underlying generator geometry seperately. That's requesting a parametric modeler to act non-parametric?
Cheers,
Markus
thomas-neemann
Post by thomas-neemann »
mfro wrote: Sat Aug 06, 2022 9:07 am ...
in part it is parametrically possible
mfro
Post by mfro »
thomas-neemann wrote: Sat Aug 06, 2022 9:12 am
Then I don't understand the request.
Cheers,
Markus
thomas-neemann
mfro wrote: Sat Aug 06, 2022 9:59 am ..
it should only be a hint that it is possible in freecad. in case someone tries it in partdesign and would otherwise give up
papyblaise
Post by papyblaise »
you can also use Sheetmetal BaseBend and Miror
clip.FCStd
(29.11 KiB) Downloaded 11 times
thomas-neemann wrote: Sat Aug 06, 2022 10:02 am in case someone tries it in partdesign and would otherwise give up
I don't understand. Both Part and PartDesign mirrors are parametric.
thomas-neemann
chrisb wrote: Sat Aug 06, 2022 12:48 pm ...
Yes, but a lot of time can be saved if the mirroring largely corresponds to what is mirrored, but changes or extensions are necessary
FBXL5
Post by FBXL5 »
thomas-neemann wrote: Sat Aug 06, 2022 9:12 am in part it is parametrically possible
I doubt that.
thomas-neemann wrote: Sat Aug 06, 2022 12:52 pm Yes, but a lot of time can be saved if the mirroring largely corresponds to what is mirrored, but changes or extensions are necessary
The mirrored side should completely correspond to the original side or I wouldn't call it mirrored.
And if a mirrored part should be extended it makes no sense to do that on sketch level.
If it has its own sketch it is not a really a mirrored object, but rather an identically built object with mirrored sketch geometry.
Shalmeneser
Post by Shalmeneser »
Same solution as @papyblaise. You don't need to modify the original sketch.
(Do I need to do a Fusion ?)
Capture d’écran 2022-08-06 155002.jpg (50.71 KiB) Viewed 575 times
BatteryClip_SHALM.FCStd
(17.01 KiB) Downloaded 18 times
thomas-neemann
FBXL5 wrote: Sat Aug 06, 2022 1:26 pm ...
I'm probably misunderstood. the founder of a mechanical engineering company complained about wasting cad time because in Inventor you couldn't create sketch-level modifications or extensions in a mirroring. I will start a new thread and make a video for it to show an example of what is meant.
